1-wire
    1-wire
    Hello. I am struggling with 1-wire data readings from my loxberry through a i2c board from the english provider ABELECTRONICS. The I-Wire bridge they use in the 1 Wire Pi Plus extension board is the DS2482-100. The Pridopia board that is referred to in the documentation is based on a DS 2482-800 bridge. Is the board I am using incompatible with the Loxberry? Anybody here with experience from this?
    • 7631
    Look into the OFWS WebUI if you Bridge is listed.
      The web OFWS WebUI responds: loxberry:3001/bus.0 Cannot find server "loxberry". Is there another way to enter the WebUI to look for the correct bridge?
      IP:3001
      Hostname in some cases didn't work.
    So what would you suggest me to do? I am from Norway, and if you prefer you could answer me in German. I will understand. But writing is a bit more difficult.
      I think, hismastersvoice asked you to use the ip address of LoxBerry instead of the hostname:
      IP:3001
      DNS resolution may sometimes fail, also in Norway ;-)
        Thank you for your suggestion. I get the same error message. Can you tell me the path to the /etc catalogue in Loxberry?
          I don’t understand...?
            Me too…
            use your ip of the loxberry / eg 192.168.1.1:3001
            If you don´t get response, maybe the OWFS Service isn`t running.
          Well. Thank you all for trying to give me a helping hand. I have been studying very hard the last 2 months, and somehow, I am getting more comfortable with the Loxberry and using Terminal. I have now got so far as to get a temperature reading on my iPhone from Loxone from using the 1wire Plugin and DS18D20 sensors. The last hurdle is to get the reading to update. When I download the config file to my Loxone Server, I get a correct reading, but no updating. Can anybody suggest a quick fix for that? Thanks!
