Cheap power consumption measurement with Broadlink sp3s
  • Sliderem
    • 30.06.2018
    • 60
    I was searching an easy way to measure power consumption for several devices in my house, I found broadlink sp3s, that is relatively cheap , between 15-20 euros/device.
    It has the possibility to have the current consumption, hourly (weekly/monthly etc...)
    This could be very important for automation as you could use easily use IF power ON than.
    Any chance to have already an existing plugin for lox-berry ?
    PS: I see that there is a plugin from the same producer for a thermostat
    https://www.loxwiki.eu/display/LOXBE...Thermostat2lox
    Could be similar ?
    Thank you in advance
  • Wörsty
    • 06.11.2015
    • 203
    I think a Loxone Smart Socket Air is the better solution.
    Christian
    Loxone Miniserver (letzte Beta) in KNX Umfeld
      Shelly Plug (16A) and Shelly Plug S (10A) are sockets with included power measuring.
      Shelly 1PM and Shelly 2.5 are flush-mounted devices with power measuring.
      Shelly 3EM can monitor the house power consumption without electrical contact to your main house cable (measuring by induction).
      All are connected by WiFi.
      With http requests, you can get the current energy in at least 10 sec steps.
      Using MQTT, you get energy changes on-the-fly.
      Zuletzt geändert von Christian Fenzl; 25.08.2020, 15:26.
      • Sliderem
        • 30.06.2018
        • 60
        Thanks !
        Do you have an example of how is this integrated in Loxberry or something similar ?
        • Sliderem
          • 30.06.2018
          • 60
          Christian
          Thanks also, I had the impression that they do not offer this functionality, nevertheless the price is quit important, but if they integrate well, it is an option
            See the MQTT Gateway Video with an example using Shelly 2:
            This is an example with Shelly Plug S in Loxone:
            • Sliderem
              • 30.06.2018
              • 60
              Thanks!
              I do not see clearly in the picture is this are suited for Belgian market, with the different ground connector...
              • Sliderem
                • 30.06.2018
                • 60
                Christian
                I see that Shelly Plug integrates relatively easy in Loxone Config as a Virtual Input.
                Having in mind that for the price of one Loxone Air I can buy 3 Shelly Plug S, what would be the main advantages of the loxone native plug ?
                  Fitting for type E, I think, no.
                  The Plug fits zu your connector, but the device plug possibly not to Shelly.
                  It is type F.
                  • Koanex
                    • 12.11.2021
                    • 16
                    Hello!
                    I also have a smart socket from Broadlink SP3S
                    I found this link, but I dont really understand to transfer to loxone.
                    maybe someone of you guys can help.
                    the idea behind was to use it like tasmota (without the chinese app behind)
                    thanks
