Plugin Text2Sip auf Ubuntu-Server-Loxberry
  • ToB204
    • 54
    Da der alte Thread zu gemacht wurde noch mal hier mein Anliegen. Ich hab mir Loxberry auf mein Ubuntu-Server installiert ( sobald es auch bei Vossifuchs funktioniert, werden wir ein kleines Howto ins Forum oder Wiki stellen). Jetzt würde ich gerne das Plugin Tex2Sip nutzen, leider gehen aber keine Anrufe raus. Hier noch mal die Log:
     Dec 5 15:38:30 modify.me found. Installing. Dec 5 15:38:30 Adapt rights / owner for files in /opt/loxberry/config/plugins/text2sip/  Dec 5 15:38:31 Copy of library libopal successfully completed. Dec 5 15:38:31 Copy of library libpt successfully completed. Dec 5 15:38:31 ERROR: Copy of library libspeexdsp failed. That is bad! Dec 5 15:38:31 ERROR: Copy of library libodbc failed. That is bad! Dec 5 15:38:31 ERROR: Copy of library libcapi20 failed. That is bad! Dec 5 15:38:31 Try to install packages (Reading database ... 153335 files and directories currently installed.) Preparing to unpack libttspico-data_1.0+git20130326-3_all.deb ... Unpacking libttspico-data (1.0+git20130326-3) over (1.0+git20130326-3) ... Setting up libttspico-data (1.0+git20130326-3) ... Dec 5 15:38:40 Package installation of libttspico-data successfully completed. Dec 5 15:38:41 ERROR: Package installation of libttspico0 failed. That is bad! Dec 5 15:38:42 ERROR: Package installation of libttspico-utils failed. That is bad! Dec 5 15:38:42 Installation completed! Dec 5 15:44:57 modify.me found. Installing. Dec 5 15:44:57 Adapt rights / owner for files in /opt/loxberry/config/plugins/text2sip/  Dec 5 15:44:57 Copy of library libopal successfully completed. Dec 5 15:44:57 Copy of library libpt successfully completed. Dec 5 15:44:57 ERROR: Copy of library libspeexdsp failed. That is bad! Dec 5 15:44:57 ERROR: Copy of library libodbc failed. That is bad! Dec 5 15:44:57 ERROR: Copy of library libcapi20 failed. That is bad! Dec 5 15:44:57 Try to install packages (Reading database ... 153335 files and directories currently installed.) Preparing to unpack libttspico-data_1.0+git20130326-3_all.deb ... Unpacking libttspico-data (1.0+git20130326-3) over (1.0+git20130326-3) ... Setting up libttspico-data (1.0+git20130326-3) ... Dec 5 15:45:08 Package installation of libttspico-data successfully completed. Dec 5 15:45:09 ERROR: Package installation of libttspico0 failed. That is bad! Dec 5 15:45:10 ERROR: Package installation of libttspico-utils failed. That is bad! Dec 5 15:45:10 Installation completed!
    Die Library´s werden da anscheinend nicht installiert. Kann ich die irgendwie nachinstallieren oder gibt es spezielle für Ubuntu ?
  • tholle
    • 830
    Versuch doch mal die Datei "libttspico0" manuell zu installieren, bzw. schau mal, wo die beim Installationsvorgang hingelegt werden soll. Evtl. fehlen Rechte, um sie im Zielordner abzulegen.
    Und pruef doch einmal die Abhaengikeiten von "libttspico0".
    So wuerde ich vorgehen.
    Gruss,
    tholle
    • ToB204
      • 54
      Also mit den Rechten ist alles in Ordnung. Hab mal vorsichtshalber dem Ordner ein chmod -R 777 verpasst. Die deb Dateien waren eine andere Architektur, hab sie gegen die arm64 getauscht. Zum download gibts die unter http://ftp.fau.de/debian/pool/non-free/s/svox/.
      Aber mit den lib´s komm ich nicht weiter, da ich keine Ahnung habe wie man die installiert.
      Dec 13 13:56:48 modify.me found. Installing.
      Dec 13 13:56:49 Adapt rights / owner for files in /opt/loxberry/config/plugins/text2sip/
      Dec 13 13:56:49 Copy of library libopal successfully completed.
      Dec 13 13:56:49 Copy of library libpt successfully completed.
      Dec 13 13:56:49 ERROR: Copy of library libspeexdsp failed. That is bad!
      Dec 13 13:56:49 ERROR: Copy of library libodbc failed. That is bad!
      Dec 13 13:56:49 ERROR: Copy of library libcapi20 failed. That is bad!
      Dec 13 13:56:49 Try to install packages
      (Reading database ... 153396 files and directories currently installed.)
      Preparing to unpack libttspico-data_1.0+git20130326-5_all.deb ...
      Unpacking libttspico-data (1.0+git20130326-5) over (1.0+git20130326-5) ...
      Setting up libttspico-data (1.0+git20130326-5) ...
      Dec 13 13:56:59 Package installation of libttspico-data successfully completed.
      Preparing to unpack libttspico0_1.0+git20130326-5_amd64.deb ...
      Unpacking libttspico0:amd64 (1.0+git20130326-5) over (1.0+git20130326-5) ...
      Setting up libttspico0:amd64 (1.0+git20130326-5) ...
      Processing triggers for libc-bin (2.19-0ubuntu6.9) ...
      Dec 13 13:57:03 Package installation of libttspico0 successfully completed.
      Preparing to unpack libttspico-utils_1.0+git20130326-5_amd64.deb ...
      Unpacking libttspico-utils (1.0+git20130326-5) over (1.0+git20130326-5) ...
      Setting up libttspico-utils (1.0+git20130326-5) ...
      Processing triggers for man-db (2.6.7.1-1ubuntu1) ...
      Dec 13 13:57:13 Package installation of libttspico-utils successfully completed.
      Dec 13 13:57:13 Installation completed!
      2016-12-13 13:58:04 [LOG] Show logfile
      Danke für die Hilfe
      Tobi
