Help With Config
    ok so. yes now i am being able to store and the server is reachable and does not "crash".
    i did tried to start the player as you said and it gave me an error of : test_open:277 playback open error : invalid argument
    out pit init_common:382 : unable to open device
    Maybe its because it is on board audio card ? and not recognised by the music server or something like thaT ?
      • 7431
      You get the Error becouse the Player could not found your soundcard.
      So we have to search why.
      Look into the Settings->Soundkarte and send the sreenshots.
          • 7431
          Intel HDA is not Supported!
          Mainboard cards are always difficult. You can compile your one driver for your card. Otherwise use PCI-e or USB Sound cards.
            • 7431
            ...if you use other cards please disabled the internal card.
              Ok master I already purchased one of the compatible cards that you mentioned. anyway,until i get it what do u think about the Network Failed error ? should i try to fix it ?
                Ok , i bought new 2 X CSL sound cards ,
                1. I disabled Onboard audio card from bios
                2. Both cards & Zones had been configured and still the internal players do not want to run
                Network intenal status : "FAILED"
                I get on terminal "Home directory not accessible: Permission denied
                [20:27:23.697757] test_open:277 playback open error: Invalid argument
                [20:27:23.697814] output_init_common:382 unable to open output device
                Squeezelite Bed wurde nicht gestartet...
                can anyone help here ?
                thanks
                  • 7431
                  I suspect that you have installed Ubuntu with English language.
                  There is a problem with writing the settings.
                  So it is needed to install in German.
                    So, I installed ubunto in german & music 4 lox
                    and i get the same error , still players can not run
                    any rabbits in the hat ?
                    Zuletzt geändert von Gast; 13.10.2017, 11:55.
                      • 7431
                      Not easy to say...
                      ​​​​​​I can offer you a TeamViewer Session so we can have a look what went wrong.
                        feel very stupid... Launching TeamViwer gui and basically it is stuck.. and getting it very hard to understand german logs, are you sure there is no way to install ubunto in english
                        • duncan
                          • 327
                          im running ubuntu in english (desktop version 16.04 lts) and havnt had any problems at all with a couple of usb 8 channel cards.
                          i have 8 internal zones, 6 squeezebox radios, 2 logitech duets and 1 boom all running fine.
                            Dear Himastervoice,
                            I installed again and again and again , and i am about to give up (though i really want to succeed)
                            when installing ubunto server there were crashes every time i tried to change something to zone, and it was not stable, and after crash server was not reachable . I read here in the post that someone (duncan) installed desktop version in english and everything worked , so i tried it , and magically , there are no crashes and setting are being saved, everything else stayed the same- players can not run when trying to open the sc player i get the same error.
                            the main problem I have now is that the players do not want to start, after zones are created and i makes players . When I start to force them in terminal (sudo sc player 1 start ) i get this error( see in screenshot).
                            I would really need another brain. hope you can help me, Adam
                            i would love to have teamviewer seasion when you can if this would help
                            • Juras
                              • 10.09.2016
                              • 36
                              hello, i have same problem
                                • 7431
                                #30
                                Gast
                                Until now I don't know the type of youro soundcards
                                Juras
                                No description of your hardware, no support!
                                Please read the rules.
