MusicServer4Lox auf Synology Docker
  • mac338
    • 22.09.2015
    • 142
    Hat jemand schon den MS4L auf eine Synology NAS Docker installiert
    • 7631
    Es wurden schon diverse Versuche mit VMs Docker usw. unternommen, die meisten ohne Erfolg.
    Der MS4L ist dafür auch nicht geschrieben worden.
    Das einzige was gut funktioniert und was ich auch ab dem nächsten Update supporte ist Proxmox.
    • madito
      • 03.07.2017
      • 132
      Hi!
      I have been using a clean installation running on XenServer / XCP-NG for about 6 months and it also works quite well.
        • 7631
        Zitat von madito
        Hi!
        Nice to hear, but at the same time it upsets me a bit.
        You are the second one who has a solution for visualization and don`t talk about.
        A lot of people here ask me about VMs, I spend a lot of time to find a soulution for these peoples.
        Than I hear that other users like you allready have found the solution, and don`t talk about. Why?
        Think about...
        I found a soultion to install a cheap multiroom server. What happens if I keep that for myself?
        That is for me not the sense of community.
        • madito
          • 03.07.2017
          • 132
          Think about...
          Hi hismaster,
          Until recently you did not support virtual machines, specifically I ran into a small problem (https://www.loxforum.com/forum/proje...lticards-on-vm)
          After reading his answer, he understood that he had no interest in the VMs. If this has changed, of course we can collaborate with the community as I currently do (I do the translations in Spanish of practically everything I use), if you remember, I will send you an MP to translate the MS4L.
          I understand that you care about the community, but I think I am not the best example for this type of message.
          If all goes well during these months of testing, I will make a small guide on the XCP-NG (Compatible with XenServer) on virtualization, including LoxBerry and MS4L.
          Again, thank you very much for your work and I am still waiting for MS4L version 1.X to translate it.
          Regards!
