Will this method of setting persistant USB audio cards work?
  • tnagpal.
    • 11.05.2019
    • 90
    https://github.com/dh1tw/remoteAudio...evices-(Linux)
    Sometimes when I reboot my device or end up reinstalling MS4L (like I just did with the move to Debian 10), the USB cards mount in a different order.
    I was thinking about using the above linked method to permanently assign the USB ports to a certain order, which I could then replicate on future installs and keep my channels in order.
    Before I went down this path - would be helpful to know whether it is worthwhile or not.
    • 7630
    The Problem with the most Soundcard is that they have the same Vendor and idProduct so it is not possible to creat a udev rule.
    That only can happens after a new installation, and than there is a easy way to change it. go to Soundcard and change the device id.
      • 2744
      in the past i even searched for a solution on this.
      Binding the ID to a specific soundcard will not work, as no soundcard i checked had a unique identification.
      The only way i found was to use the physical USB port to get the ID bound so something useful, but don't ask my how to do this, i gave up after a while.
      but as hismastersvoice already wrote, a new mapping might only happen after a installation of a new system.
      • tnagpal.
        • 11.05.2019
        • 90
        I'd suggest that even permanent mapping of USB ports would be useful since you could then replicate that mapping on a subsequent install or move to a different system with a bit less fuss. Not a huge deal either way.
          Labmaster kommentierte
          You are welcome to get this documented.
