Am RPI 3 mit 4 Stereo Zonen Ist der Sound nach ein paar Stunden (ca. 2-3) total abgehakt.
Wenn Ich den Player im LMS Interface mit Power beende und mit Play neu starte geh es wider ein paar Stunden.
Bei den externen Zonen ist das nicht
Jemand eine Idee was da sein kann?
MusicServer4Home
VERS=1.3.0.0
OS
DISTRO="Raspbian GNU/Linux 10 (buster)"
KERNEL="Linux 5.10.11-v7+ armv7l"
Hardware
DMI_MANUFACTURER="Raspberry Pi 3 Model B Rev 1.2"
CPU_NAME=" ARMv7 Processor rev 4 (v7l)"
CPU_USAGE="64.3216"
MEMUSED="859"
MEMTOTAL="946"
MEMFREE="87"
DISK_TOTAL="14.38"
DISK_USED="2.50"
DISK_FREE="11.88"
UPWEEKS="0"
UPDAYS="1"
UPHOURS="6"
UPMINUTES="33"
Network
INTERNET="0"
HOSTNAME="MS4HomeRpi.local"
INTERN_TIME="0.18"
INTERN_LOSS="0"
INTERN_REACH="1"
GATEWAY_TIME="0.64"
GATEWAY_LOSS="0"
GATEWAY_REACH="1"
DNS_TIME=" 11.6"
DNS_LOSS="0"
DNS_REACH="1"
MINISERVER_TIME="0.55"
MINISERVER_LOSS="0"
MINISERVER_REACH="1"
Zones
Player intern: 1 01 / 01:27:eb:36:a0:2b / zone_01_eq / 80:4::
Player intern: 2 02 / 02:27:eb:36:a0:2b / zone_02_eq / 80:4::
Player intern: 3 03 / 03:27:eb:36:a0:2b / zone_03_eq / 80:4::
Player intern: 4 04 / 04:27:eb:36:a0:2b / zone_04_eq / 80:4::
Player extern: 1 01 / 01:27:eb:36:a0:2b
Player extern: 2 Max2Play / b8:27:eb:5d:aa:86
Logitech Media Server
LMS_VERS="8.2.0~1614180387"
LMS IP=10.1.21.164
LMS_WEB="1"
LMS PORT=9090
LMS_TEL="1"
Squeezelite
SQLITE_VERS="1.9.9-1356"
squeezelite -n 01 -m 01 27 eb 36 a0 2b -o zone_01_eq -a 80 4 -s 10.1.21.164 -M MusicServer4Home-Player
squeezelite -n 02 -m 02 27 eb 36 a0 2b -o zone_02_eq -a 80 4 -s 10.1.21.164 -M MusicServer4Home-Player
squeezelite -n 03 -m 03 27 eb 36 a0 2b -o zone_03_eq -a 80 4 -s 10.1.21.164 -M MusicServer4Home-Player
squeezelite -n 04 -m 04 27 eb 36 a0 2b -o zone_04_eq -a 80 4 -s 10.1.21.164 -M MusicServer4Home-Player
Soundcard(s)
1 [ICUSBAUDIO7D ]: USB-Audio - ICUSBAUDIO7D
Output Devices
Output devices:
null - Discard all samples (playback) or generate zero samples (capture)
jack - JACK Audio Connection Kit
pulse - PulseAudio Sound Server
card_0
multi
default
allchannel
zone_01
zone_01_eq
zone_02
zone_02_eq
zone_03
zone_03_eq
zone_04
zone_04_eq
sysdefault:CARD=ICUSBAUDIO7D - ICUSBAUDIO7D, USB Audio - Default Audio Device
front:CARD=ICUSBAUDIO7D,DEV=0 - ICUSBAUDIO7D, USB Audio - Front speakers
surround21:CARD=ICUSBAUDIO7D,DEV=0 - ICUSBAUDIO7D, USB Audio - 2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=ICUSBAUDIO7D,DEV=0 - ICUSBAUDIO7D, USB Audio - 4.0 Surround output to Front and Rear speakers
surround41:CARD=ICUSBAUDIO7D,DEV=0 - ICUSBAUDIO7D, USB Audio - 4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=ICUSBAUDIO7D,DEV=0 - ICUSBAUDIO7D, USB Audio - 5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=ICUSBAUDIO7D,DEV=0 - ICUSBAUDIO7D, USB Audio - 5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=ICUSBAUDIO7D,DEV=0 - ICUSBAUDIO7D, USB Audio - 7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=ICUSBAUDIO7D,DEV=0 - ICUSBAUDIO7D, USB Audio - IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=ICUSBAUDIO7D,DEV=0 - ICUSBAUDIO7D, USB Audio - Direct sample mixing device
dsnoop:CARD=ICUSBAUDIO7D,DEV=0 - ICUSBAUDIO7D, USB Audio - Direct sample snooping device
hw:CARD=ICUSBAUDIO7D,DEV=0 - ICUSBAUDIO7D, USB Audio - Direct hardware device without any conversions
plughw:CARD=ICUSBAUDIO7D,DEV=0 - ICUSBAUDIO7D, USB Audio - Hardware device with all software conversions
usbstream:CARD=ICUSBAUDIO7D - ICUSBAUDIO7D - USB Stream Output
Portscan
Port 22 reachable
Port 80 reachable
Port 443 not reachable
Port 7091 reachable
Port 7092 reachable
Port 9000 reachable
Port 9090 reachable
MSG Config
"plugin": "lms",
"zones": 5,
"zone_map": {"1": "01:27:eb:36:a0:2b","2": "02:27:eb:36:a0:2b","3": "03:27:eb:36:a0:2b","4": "04:27:eb:36:a0:2b","5": "01:27:eb:36:a0:2b"
"ip": "10.1.21.164",
"lms_host": "localhost",
"lms_port": 9000,
"lms_cli_port": 9090,
"macAddress": "b8:27:eb:36:a0:2b",
"useSlowQueueWorkaround": true,
"cors_port": 7092,
"ms": {
"host": "10.0.0.230:80",
"users": [
"{ all users and passwords were blanked }"
"sayFav": true,
"filteredRadioEntries": [ "language","search","presets","picks" ],
"filteredSpotifyEntries": [ ],
"scripts": {
"playUploadedFile": "wget -4 -q -O - 'http://10.1.21.164/include/set_msg.php?do=announcement&zone_msg={{zones}}'",
"playAlarmSound": "wget -4 -q -O - 'http://10.1.21.164/include/set_msg.php?do=event&zone_msg={{zones}}&event_name ={{name}}&event_typ={{type}}&event_volume={{volume }}'",
"playTTS": "wget -4 -q -O - 'http://10.1.21.164/include/set_msg.php?do=event&zone_msg={{zones}}&event_name ={{name}}&event_text={{text}}&event_volume={{volum e}}'",
"changeEqualizer": "wget -4 -q -O - 'http://10.1.21.164/include/set_msg.php?do=eq&zone_msg={{zones}}'",
"changeDefaultVolume": "wget -4 -q -O - 'http://10.1.21.164/include/set_msg.php?do=defaultVolume&zone_msg={{zones}}'",
"changeMaxVolume": "echo {{name}} {{zones}} {{maxVolume}}",
"addNetworkShare": "echo {{name}} {{server}} {{guest}} {{username}} {{password}} {{configBase64}}",
"sayFav": "wget -4 -q -O - 'http://10.1.21.164/include/set_msg.php?do=event&zone_msg={{zones}}&event_name ={{name}}&event_text={{fav_name}}&event_volume={{v olume}}'"
"uploadPath": "/var/www/event/tts_tmp",
"uploadPlaybackPath": "/var/www/event/tts_tmp"
