LMS IP address request
  • J V
    • 385
    Hello,
    Perhaps a strange question, but is there a reason why it is not possible to change the LMS IP Address?
    I would love to use the musicserver4home with an LMS hosted on a different computer...
    Thanks,
    Jörg
    • 7663
    Not possible, LMS had to run on the same system.
    To deep integrated, and makes absolute no sense to use LMS on an other device than MS4H
    • J V
      • 385
      I was afraid that this would be the case. Thanks for answering so quickly!!
        • 7663
        Tell me what is the reason to use the LMS on an other system?
        • J V
          • 385
          I have a media server on which I have all my media, and would prefer to keep it like that.
          I thought pointing MS4H to a different LMS would be the easiest. As that is not an option, I'm now thinking about using the netshare mount to give the LMS installation on the MS4H access to the music files on the media server. As long as all my music is in a single folder structure (and I share that root), it should be doable to point LMS to the mounted share.
          One small question: do you have a list of the ports MS4H use?
            • 7663
            Connect to network share (CIFS) is settable by WebUI
            Ports
            80 WebUI
            9000 LMS
            9090 LMS CLI
            7091 Loxone App
            • J V
              • 385
              Yes, I found that netshare function, so I have a solution.
              Thanks for the ports information.
              I'll start playing with it soon.
