LMS not starting
  • yavel
    • 21.01.2021
    • 26
    LMS not starting
    Hello,
    After installing MS4H on my raspberry 4 everything worked fine.
    I set up LMS and installed spotty. But after a reboot, LMS doesn't start up anymore. It stays red in the MS4H dashboard. Force stopping and rebooting doesn't help.
    Does somebody know a solution?
    Thank you!
    • 7663
    What raspi 4 do you use...
    ​​​​​​Hardware detection doesn't work
    As I gave written in the help you gave to use the beta for raspi with bullseye.
    • hme0354
      hme0354 kommentierte
      Looks like raspberry 4 with 4gb ram and sound like my issues we discused last week
      Different to your problem...
      Raspbian 11 works only with beta
      IP reads out correct , netmask is fixed in latest beta.
      SD Card should read out correct on 10 and 11 because there are no different in the filesystem.
    • hme0354
      I ment the problem with LMS, which did not start up. Because of that I made a new installation
  • yavel
    • 21.01.2021
    • 26
    Allright, thank you for your comments. I installed the beta and have everything up and running now. Many thanks for your help.
    The only thing not working for me is the search function. It just keeps on searching and never gives a result unfortunatly. Is this a known issue?
    • yavel
      • 21.01.2021
      • 26
      Next to that I made an audio building block for my bathroom. I want the music to start when I enter and to stop 15 seconds after I left. This is currently not working and I don't know what I'm doing wrong here. Does somebody have the answer or an example of their building blocks?
      • yavel
        • 21.01.2021
        • 26
        I found out what the problem was in the config. First the input needs to be Mv (Movement) and not P (Presence) as music will keep on triggering P. Secondly I chose "give ON signal" in the parameters.
        Searching is still not working though.
