Music Server Radio
  • digi77
    • 24.09.2019
    • 38
    Music Server Radio
    I have a loxone music server but I'm looking at setting up a MS4H use existing hardware but add a few extra zones with additional soundcard. What I can't work out is we use Tunein for radio can this be done on MS4H and is it possible to add say plugins for other internet radio suppliers?
    • 7663
    Theoretical yes , but I don't know what MusicServer (amount of Zones) you use, and so I can't say anything
    The Triggercard of the org. MusicServer is not supported.
    Normal you can set PCIe Xonard Cards to the existing system, and setup.
    Don't know what "say plugins" are.
    • digi77
      • 24.09.2019
      • 38
      Hi, I have the 8 zone music server.
      If the original trigger card is not supported is there a work around ?
      Does MS4H have Tunein ?
      If you know the URL of a radio stream can this be added as say a favourite to play anytime.
        • 7663
        Trigger-Card... You can use a HID USB-Relay like THIS
        TuneIn
        The base of the MS4H is the same as Loxone org. MusicServer the Logitech Media Server. So yes TuneIn works like with the org. MusicServer
        For sure you can use an URL as a Fav. go to the WebUI of the LMS and save it.
        One thing to know for you.
        The Line in of the Soundcards are at the moment only usable with some additional handwork.
        But there are Threads here in Forum that show how.
        • digi77
          • 24.09.2019
          • 38
          Thanks for you help, I don't use line in at the moment so will give it ago will order a trigger relay.
