| Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz, 4 Kerne |
| Speicher | 833.06 MB genutzt / 7.60 GB gesamt |
| Lokaler HDD-Speicher | 49.56 GB genutzt / 866.27 GB frei / 915.83 GB gesamt |
ohne laufende Player liegt die CPU Last bei 1%
| 1 | root | 07:21 | /sbin/init |
| 376 | root | 07:21 | /lib/systemd/systemd-journald |
| 428 | root | 07:21 | /sbin/lvmetad -f |
| 436 | root | 07:21 | /lib/systemd/systemd-udevd |
| 520 | systemd-timesync | 07:21 | /lib/systemd/systemd-timesyncd |
| 782 | root | 07:21 | /usr/sbin/cron -f |
| 784 | root | 07:21 | /lib/systemd/systemd-logind |
| 789 | messagebus | 07:21 | /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd- ... |
| 814 | syslog | 07:21 | /usr/sbin/rsyslogd -n |
| 820 | daemon | 07:21 | /usr/sbin/atd -f |
| 822 | avahi | 07:21 | avahi-daemon: running [MS4L.local] |
| 865 | avahi | 07:21 | avahi-daemon: chroot helper |
| 824 | root | 07:21 | /usr/lib/accountsservice/accounts-daemon |
| 826 | root | 07:21 | /usr/sbin/acpid |
| 828 | root | 07:21 | /usr/bin/lxcfs /var/lib/lxcfs/ |
| 830 | root | 07:21 | /usr/lib/snapd/snapd |
| 862 | root | 07:21 | /usr/lib/policykit-1/polkitd --no-debug |
| 888 | root | 07:21 | /sbin/mdadm --monitor --pid-file /run/mdadm/monitor.pid --daemonise --scan --sys ... |
| 945 | root | 07:21 | /usr/sbin/smbd -D |
| 963 | root | 07:21 | /usr/sbin/smbd -D |
| 984 | root | 07:21 | /usr/sbin/smbd -D |
| 991 | root | 07:21 | /sbin/dhclient -1 -v -pf /run/dhclient.eno1.pid -lf /var/lib/dhcp/dhclient.eno1. ... |
| 1114 | root | 07:21 | /sbin/iscsid |
| 1115 | root | 07:21 | /sbin/iscsid |
| 1125 | root | 07:21 | /usr/sbin/sshd -D |
| 6588 | root | 07:30 | sshd: musik [priv] |
| 6779 | musik | 07:31 | sshd: musik@pts/0 |
| 6783 | musik | 07:31 | -bash |
| 1217 | root | 07:21 | /usr/sbin/irqbalance --pid=/var/run/irqbalance.pid |
| 1234 | root | 07:21 | /usr/sbin/nmbd -D |
| 1235 | root | 07:21 | /usr/sbin/winbindd |
| 1242 | root | 07:21 | /usr/sbin/winbindd |
| 8441 | root | 07:58 | /usr/sbin/winbindd |
| 1314 | root | 07:21 | /usr/sbin/apache2 -k start |
| 1394 | www-data | 07:21 | /usr/sbin/apache2 -k start |
| 1395 | www-data | 07:21 | /usr/sbin/apache2 -k start |
| 2965 | www-data | 07:23 | /usr/sbin/apache2 -k start |
| 2968 | www-data | 07:23 | /usr/sbin/apache2 -k start |
| 2971 | www-data | 07:23 | /usr/sbin/apache2 -k start |
| 4386 | www-data | 07:26 | /usr/sbin/apache2 -k start |
| 8161 | www-data | 07:34 | /usr/sbin/apache2 -k start |
| 9615 | www-data | 08:11 | /usr/sbin/apache2 -k start |
| 26329 | www-data | 08:21 | /usr/sbin/apache2 -k start |
| 27173 | www-data | 08:25 | /usr/sbin/apache2 -k start |
| 28927 | www-data | 10:54 | /usr/sbin/apache2 -k start |
| 29283 | root | 11:21 | sh -c ps --cols 2048 -eo user:80,ruser:80,group:80,rgroup:80,pid,ppid,pgid, pcpu, ... |
| 29284 | root | 11:21 | ps --cols 2048 -eo user:80,ruser:80,group:80,rgroup:80,pid,ppid,pgid, pcpu,vsz,ni ... |
| 2082 | root | 07:21 | /sbin/agetty --noclear tty1 linux |
| 3279 | root | 07:23 | sudo sc autostop |
| 3280 | root | 07:23 | /bin/bash /bin/sc autostop |
| 5310 | root | 07:29 | socat - udp4-listen:9001,reuseaddr,fork |
| 6716 | musik | 07:31 | /lib/systemd/systemd --user |
| 6721 | musik | 07:31 | (sd-pam) |
| 7972 | root | 07:34 | sudo /opt/music_server/mstools update_lms |
| 7973 | root | 07:34 | /bin/bash /opt/music_server/mstools update_lms |
| 7980 | root | 07:34 | sudo sc autostop |
| 7981 | root | 07:34 | /bin/bash /bin/sc autostop |
| 8215 | root | 07:35 | sudo sc autostop |
| 8216 | root | 07:35 | /bin/bash /bin/sc autostop |
| 9530 | root | 08:11 | sudo /opt/music_server/mstools update_lms |
| 9531 | root | 08:11 | /bin/bash /opt/music_server/mstools update_lms |
| 9538 | root | 08:11 | sudo sc autostop |
| 9539 | root | 08:11 | /bin/bash /bin/sc autostop |
| 9987 | root | 08:12 | sudo sc autostop |
| 9988 | root | 08:12 | /bin/bash /bin/sc autostop |
| 10566 | root | 08:14 | sudo /opt/music_server/mstools update_lms |
| 10567 | root | 08:14 | /bin/bash /opt/music_server/mstools update_lms |
| 10574 | root | 08:14 | sudo sc autostop |
| 10575 | root | 08:14 | /bin/bash /bin/sc autostop |
| 26820 | root | 08:24 | sudo /opt/music_server/mstools update_lms |
| 26821 | root | 08:24 | /bin/bash /opt/music_server/mstools update_lms |
| 26828 | root | 08:24 | sudo sc autostop |
| 26829 | root | 08:24 | /bin/bash /bin/sc autostop |
| 2 | root | 07:21 | [kthreadd] |
| 3 | root | 07:21 | [ksoftirqd/0] |
| 5 | root | 07:21 | [kworker/0:0H] |
| 7 | root | 07:21 | [rcu_sched] |
| 8 | root | 07:21 | [rcu_bh] |
| 9 | root | 07:21 | [migration/0] |
| 10 | root | 07:21 | [watchdog/0] |
| 11 | root | 07:21 | [watchdog/1] |
| 12 | root | 07:21 | [migration/1] |
| 13 | root | 07:21 | [ksoftirqd/1] |
| 15 | root | 07:21 | [kworker/1:0H] |
| 16 | root | 07:21 | [watchdog/2] |
| 17 | root | 07:21 | [migration/2] |
| 18 | root | 07:21 | [ksoftirqd/2] |
| 20 | root | 07:21 | [kworker/2:0H] |
| 21 | root | 07:21 | [watchdog/3] |
| 22 | root | 07:21 | [migration/3] |
| 23 | root | 07:21 | [ksoftirqd/3] |
| 25 | root | 07:21 | [kworker/3:0H] |
| 26 | root | 07:21 | [kdevtmpfs] |
| 27 | root | 07:21 | [netns] |
| 28 | root | 07:21 | [perf] |
| 29 | root | 07:21 | [khungtaskd] |
| 30 | root | 07:21 | [writeback] |
| 31 | root | 07:21 | [ksmd] |
| 32 | root | 07:21 | [khugepaged] |
| 33 | root | 07:21 | [crypto] |
| 34 | root | 07:21 | [kintegrityd] |
| 35 | root | 07:21 | [bioset] |
| 36 | root | 07:21 | [kblockd] |
| 37 | root | 07:21 | [ata_sff] |
| 38 | root | 07:21 | [md] |
| 39 | root | 07:21 | [devfreq_wq] |
| 44 | root | 07:21 | [kswapd0] |
| 45 | root | 07:21 | [vmstat] |
| 46 | root | 07:21 | [fsnotify_mark] |
| 47 | root | 07:21 | [ecryptfs-kthrea] |
| 63 | root | 07:21 | [kthrotld] |
| 64 | root | 07:21 | [acpi_thermal_pm] |
| 66 | root | 07:21 | [bioset] |
| 67 | root | 07:21 | [bioset] |
| 68 | root | 07:21 | [bioset] |
| 69 | root | 07:21 | [bioset] |
| 70 | root | 07:21 | [bioset] |
| 71 | root | 07:21 | [bioset] |
| 72 | root | 07:21 | [bioset] |
| 73 | root | 07:21 | [bioset] |
| 75 | root | 07:21 | [ipv6_addrconf] |
| 89 | root | 07:21 | [deferwq] |
| 90 | root | 07:21 | [charger_manager] |
| 137 | root | 07:21 | [kpsmoused] |
| 152 | root | 07:21 | [scsi_eh_0] |
| 155 | root | 07:21 | [scsi_tmf_0] |
| 156 | root | 07:21 | [scsi_eh_1] |
| 157 | root | 07:21 | [scsi_tmf_1] |
| 158 | root | 07:21 | [scsi_eh_2] |
| 159 | root | 07:21 | [scsi_tmf_2] |
| 171 | root | 07:21 | [scsi_eh_3] |
| 172 | root | 07:21 | [scsi_tmf_3] |
| 173 | root | 07:21 | [scsi_eh_4] |
| 174 | root | 07:21 | [scsi_tmf_4] |
| 175 | root | 07:21 | [scsi_eh_5] |
| 176 | root | 07:21 | [scsi_tmf_5] |
| 183 | root | 07:21 | [bioset] |
| 184 | root | 07:21 | [bioset] |
| 187 | root | 07:21 | [kworker/1:1H] |
| 257 | root | 07:21 | [raid5wq] |
| 283 | root | 07:21 | [bioset] |
| 311 | root | 07:21 | [kworker/0:1H] |
| 313 | root | 07:21 | [jbd2/sda1-8] |
| 314 | root | 07:21 | [ext4-rsv-conver] |
| 371 | root | 07:21 | [kworker/0:2] |
| 375 | root | 07:21 | [kauditd] |
| 394 | root | 07:21 | [kworker/3:2] |
| 427 | root | 07:21 | [iscsi_eh] |
| 433 | root | 07:21 | [ib_addr] |
| 439 | root | 07:21 | [ib_mcast] |
| 440 | root | 07:21 | [ib_nl_sa_wq] |
| 441 | root | 07:21 | [ib_cm] |
| 442 | root | 07:21 | [iw_cm_wq] |
| 443 | root | 07:21 | [rdma_cm] |
| 545 | root | 07:21 | [edac-poller] |
| 552 | root | 07:21 | [irq/28-mei_me] |
| 846 | root | 07:21 | [kworker/2:1H] |
| 910 | root | 07:21 | [kworker/3:1H] |
| 1156 | root | 07:21 | [kworker/2:3] |
| 8381 | root | 07:36 | [kworker/3:1] |
| 9424 | root | 08:06 | [kworker/1:1] |
| 10853 | root | 08:17 | [kworker/1:2] |
| 10856 | root | 08:17 | [kworker/0:0] |
| 28850 | root | 10:43 | [kworker/2:1] |
| 28859 | root | 10:45 | [kworker/u8:0] |
| 28959 | root | 11:01 | [kworker/u8:1] |
