Ankündigung
Keine Ankündigung bisher.
Virtual http command cant retrieve values???
  • Filter
  • Virtual http command cant retrieve values???
    I would like to receive weather info via openweathermap. I subscribed there and received a dedicated api.
    I than can create a link like http://samples.openweathermap.org/da...fae22&mode=xml to get the weather data.
    I've added the link as a virtual http input. Than i added a virtual http input command to get the actual temperature.
    i've tried
    value="\v
    \ivalue="\i\v
    <temperature value="\v
    \itemperature\i\v
    and a lot other options that i forgot.
    i've also tried with removing the &mode=xml from the link to try and get the data from the site in a different format. I've tried changing the \ v to 1,#,...
    Nothing however seems to work. In liveview the value remains 0 of the virtual input.
    Any suggestions on what i 'm doing wrong would be greatly appreciated.
    Zuletzt geändert von ty5500; 12.Jun.2018, 00:20.
  • #2
    Zitat von ty5500 Beitrag anzeigen
    ...I've added the link as a virtual http input. Than i added a virtual http input command to get the actual temperature.
    This configuration should work.
    URL: The complete Link You show above
    Command recognition: temperature value="\v
    Did You safe it into your miniserver, and did you wait the time you set into Polling cycle [s]?
    • #3
      It works now. The command was as you said correct. My miniservers subnet gateway/dns server however wasnt configured correctly (not with the ip adress of the router) and this caused it to not be able to retrieve the values. Thanks!!
        You´re welcom.
