AND port
  • nico louis
    • 19.05.2019
    • 13
    AND port
    hi all
    something i came across today and can't figur out why an On and On on an and port won't give me on?
    Doens't it work on equal states?
    to be clear in the picture you will see dutch but here is the translation
    AAN = ON
    UIT = OFF
    i initialy had no equal block but it didn't work then, so i thought that maybe 'afwezig' (translated noone at home) was an analog output.
    That's why i placed the equal block but still no change behind the and port.
  • Thomas Kührer
    • 402
    Hello,
    the Connections to one Port fron an AND are also AND, connect the 4(5) Signals to an OR an dthen to the AND Port.
    I hope you understand what I mean, my English is not the Yellow from the Egg
    • nico louis
      • 19.05.2019
      • 13
      Hi Thomas
      I did understand you. and it fixed the problem, only i don't know why...
      Placing the connections in parallel or trought 'OR' ports shouldn't make a difference.
      Or is it because i use KNX push buttons? Do the or ports have an internal 'ON' detection (Flank trigger)
        I don’t see the mistake in your second shot...?
        Every connection to an AND, even multiple connections to the same connector, is connected as AND.
