Sending analog values inside Virtual Output (HTTP POST)
    Hi!
    How to send analog value inside Virtual Output command (http POST request).
    I can't get the syntax.
    What chars should I use to send digits (initially sent by analog value input) instead of XX inside http POST (see the screen) ?
    <v> and \1 don't work
  • duncan
    • 364
    you need to replace your XX with <v> and turn off the tick next to digital output, then it should replace the <v> with the value of the virtual output
      I appreciate your help!
      It worked!
