Can't retract values from site
  • ty5500
    • 11.06.2018
    • 37
    the following link gives me the rain forecast for a location (https://gpsgadget.buienradar.nl/data...t?lat=51&lon=3). If no rain is forecasted the hourly numbers are zero.
    I want to retrieve the first three number of this link in loxone. this is the forecasted rain for the present time. this so i can close my sunshades if it is higher than zero.
    I can't seem to retract these numbers with a virtual http input (\v). Could you please assist as i've tried everything?
    Also, is there a possibility to extract weather data from sites such as : https://www.buienradar.be/weer/Grote%20Heide/BE/2796956?
    Currently i use a darksky api to retract weather data but certainly for rain it is not always reliable enough.
    Thanks for your appreciated advice.
    Zuletzt geändert von ty5500; 12.04.2020, 21:01.
  • Tico
    • 31.08.2016
    • 1035
    Both sites use https. The Miniserver doesn't work for https sites.
    There is a workaround using the Loxberry and the https2http plugin.
    Otherwise find a resource that uses http.
    • Gerd Clever
      • 24.07.2016
      • 642
      I think that is not a problem, because http://gpsgadget.buienradar.nl/data/...t?lat=51&lon=3 works too.
      To retrieve the first three values I suggest:
      value 1: \v
      value 2: \s10\v
      value 3: \s20\v
      But I didn't test it. If it fails, you can combine \v, \ixxx\i, \r and \n.
      Zuletzt geändert von Gerd Clever; 13.04.2020, 05:57.
      • ty5500
        • 11.06.2018
        • 37
        Thanks, works like a charm after i changed it to http. Didn't know the virtual http input didn't support https. It's however a bit strange as my darksky link was also https.
        • Tico
          Tico kommentierte
          Darksky is an interesting case... It's address is https but it's not an encrypted site (owing to the fact the Miniserver can't decrypt https).
          But it also shows the padlock symbol in Chrome browser (which suggests it is an encrypted connection).
          Perhaps someone has an explanation?
        • HBeumer
          HBeumer kommentierte
          darksky is now part of apple and by the end of 2021 the API will no longer be available to others...
        • HBeumer
          Can you share a few screenshots how you've made this work? I need to migrate away from Darksky and buienradar would be a good option for my location (Central NL)
      • HBeumer
        • 24.02.2017
        • 47
        interesting, do you happen to have a XML file to ease the integration with Loxone for others?
        • ty5500
          • 11.06.2018
          • 37
          More information regarding darksky and the xml template is available on https://www.loxwiki.eu/display/LOX/D...xone+einbinden. For me, i registered in the past (when they still allowed subscriptions) and using the custom darksky https link (with personal token) i can retrieve the weather values with the miniserver and a virtual http input command with no problems.
          • ty5500
            • 11.06.2018
            • 37
            Hi HBEUMER, it attached 2 screenshots of how i use it for buienradar. I only detect when it's going to rain to close my sun shades.
            Zuletzt geändert von ty5500; 19.06.2020, 20:00.
              Hi all,
              my first time post overhere...
              I have a Okofen Pellematic heating system that has modBus and Json implementation on it... I've bought the Loxone modbus module but for a strange reason it doesn't work. (I have a case open with Loxone Belgium)
              So I started to think that I might do it with JSON ... but im stuck as well.
              I've included the json data as attachment.
              How can I for example read out the following value?
              "L_ambient" : "166", which is 16.6 degrees outside temperature
              I tried with system\iL_ambient":"\i'v but it still show as 0 in the live view.
              thanks in advance!
              Jimmy
                It is very important that you use the raw content, not any pre-formatted json output from the Browser or an editor. White spaces might have been changed through a pretty-print output.
                Check the raw output. If you have LoxBerry, try the Command Recognition plugin.
                  You have written ‘v this is a typo in your post? Should be \v
                  Hi Christian... I managed to do this with your tip for using raw data: L_ambient= it did that fine but it shows up as 234 and it should be 23.4 degrees. I looking into a math module in Loxone but couldn't find it. Or can I do this from the query itself?
                  now an hour later when checking the value it still shows up as 234 and its 21.9 degrees outside... hmmm.. strange
                  Zuletzt geändert von Gast; 27.08.2020, 17:35. Grund: edited the "hour later"
                Hi Christian thanks for your update... I tried with the \v in the end but that doesn't work either.. I will try installing loxberry later today on a spare Pi I have lying around...
                • HBeumer
                  • 24.02.2017
                  • 47
                  I've finally found some time to invest in moving from the darksky data to the KNMI data (relevant mostly for NL) through weerlive.nl. The response is:
                  { "liveweer": [{"plaats": "Amsterdam", "temp": "17.2", "gtemp": "15.8", "samenv": "Geheel bewolkt", "lv": "84", "windr": "ZO", "windms": "3", "winds": "2", "windk": "5.8", "windkmh": "10.8", "luchtd": "1015.4", "ldmmhg": "762", "dauwp": "14", "zicht": "14", "verw": "Afwisseling van wolkenvelden en zon, lokaal een bui. Morgen meer buien", "sup": "06:43", "sunder": "20:40", "image": "bewolkt", "d0weer": "bewolkt", "d0tmax": "20", "d0tmin": "11", "d0windk": "2", "d0windknp": "6", "d0windms": "3", "d0windkmh": "11", "d0windr": "Z", "d0neerslag": "17", "d0zon": "14", "d1weer": "regen", "d1tmax": "20", "d1tmin": "14", "d1windk": "3", "d1windknp": "8", "d1windms": "4", "d1windkmh": "15", "d1windr": "ZW", "d1neerslag": "90", "d1zon": "30", "d2weer": "regen", "d2tmax": "19", "d2tmin": "13", "d2windk": "2", "d2windknp": "6", "d2windms": "3", "d2windkmh": "11", "d2windr": "W", "d2neerslag": "80", "d2zon": "20", "alarm": "0"}]}
                  whenever the variable is a number it comes through without issues. However I'm struggling to get the following data into loxone appropriately:
                  "sup": "06:43" --> "sup": "\v --> Only seems to provide the piece in front of the colon (hours) but not the part after it (the minutes).
                  "windr": "ZO" --> "windir" : "\v --> I only get the value 0. How on earth can I capture a string?
                    Strings cannot directly be read, but only by a workaround.
                    By using \1 you can read the ASCII code of one character.
                    For example
                    "windir": "\i --> Z --> 90
                    "windir": "\.\i --> O --> 79
                    With a status block, you can back-convert the numbers to letters. It is important to know all combinations. If there would be a windr of ZZO you also would require additional logic to recognize three letters instead of two.
                    With the time, you can use
                    "sup": "\v
                    "sup": "\s3\v
                    that gives you two numbers, that also by a status block can be re-combined (<v1>:<v2>).
                    • HBeumer
                      • 24.02.2017
                      • 47
                      For example
                      "sup": "\v
                      "sup": "\s3\v
                      Uh, oh... the "windir" parameter can have 2 letter and 3 letter values. e.g. ZO and NNO. what would the outcome be for the 3rd letter if the string is only 2 letters long?
                      "windir": "\.\.\i --> ? --> ??
                      Zuletzt geändert von HBeumer; 01.09.2020, 09:39.
                        A complete list of all ASCII codes, characters, symbols and signs included in the 7-bit ASCII table and the extended ASCII table according to the Windows-1252 character set, which is a superset of ISO 8859-1 in terms of printable characters.
                        " --> 34
                        • HBeumer
                          • 24.02.2017
                          • 47
                          Thanks a lot Christian Fenzl . I've managed to make it work using a status block and the splitting of the ASCII codes. Right now I've migrated away from Darksky onto the Dutch weather service site works like a charm
