Loopback to webservice
  • J V
    • 385
    Hello,
    I'm using a Virtual Input to have an up/down input-widget in the user-interface, but need to populate the value. I'm trying to use the webservices, which works from a browser:
    http://user@password:miniserverIP/dev/sps/io/<inputname>/<value>
    But I cannot seem to get this to work from a virtual output on the same miniserver. I think I've tried everything: post, get, miniserver://, http://, name of the object, name of the input (VI2), ... nothing I can send from the miniserver seems to set the value, from elsewhere it works fine...
    Any thoughts?
    Hello,
    Did you try
    Preferences (Virtual Output)
    Address:
    Preferences (Virtual Output Command)
    Command for On:
    HTTP methode for ON: GET
    Use as digital output: not selected
    • J V
      • 385
      That is what I was doing... I tried again but it does not work...
      In LiveView I see that the output has the value, but the input never gets it...
      • J V
        • 385
        It took me 2 hours yesterday, and half an hour today to suddenly realize that I have http://username@password:miniserverIP
        Somehow I kept looking over this error...
        Thanks you for your reply, it made me triple check everything.
          Yes, this should work:
          [URL="http://username@password:miniserverIP"]http://username:password@miniserverIP[/URL]
          and that doesn't work:
          [URL="http://username@password:miniserverIP"]http://username@assword:miniserverIP[/URL]
          • J V
            • 385
            Yep... Weird how a person can keep reading over the same stupid time and time again, and it somehow does not register...
            Your post told me that I was doing it conceptually right, so it had to be something stupid... Thanks
              you're welcome
