Memory Flag: delay question
  • J V
    • 386
    Hello,
    I think I've been misinterpreting the delay-option in a Memory Flag... According to the description, it is "Delay input, by x cycles, to the output". Suppose I have a memory flag A with delay 0 and a flag B with delay 1, both connected to some analogue value V (edit: V is an analog output).
    I thought that at any point, the value A reflects the current value of V, and the value B reflects the value in the previous cycle, but it appears that if V does not change, neither does B. As such, the description "by x cycles" is NOT machine cycles (as I thought) but rather "value changes of V"...
    I tried to explain it in a table, suppose V varies as shown in the second row.
    cycle 1 2 3 4 5 6 7 8 9
    V 5 5 6 7 8 8 8 9 9
    A exepected 5 5 6 7 8 8 8 9 9
    B exepected - 5 5 6 7 8 8 8 9
    A observed 5 5 6 7 8 8 8 9 9
    B observed - 5 5 6 7 7 7 8 8
    In bold I highlighted the values that were surprising to me.
    I hadn't used those delays much, but started to use them and was struggling...
    Do I now have the correct interpretation of how the delay works?
    Thanks!
    EDIT: I'm unable to reproduce this behaviour, the observed output is the expected output.
    Jörg
    Zuletzt geändert von J V; 23.12.2020, 10:39.
    You cannot connect two analogue values to one analogue input. The design of your test is wrong.
    • J V
      • 386
      There is one analogue value V, V is an analog output... and then one memory flag A with delay=0, and one memory flag B with delay =1, both taking V as an input.
      The lines "expected" is what I thought it would give, the lines "observed" are what it gives...
      Zuletzt geändert von J V; 22.12.2020, 18:20.
        • 5182
        I cannot confirm your observations.
        In my attempts it behaves as expected in the list
        Cofig V11.1.9.14
        • J V
          • 386
          So it should be like my expected behaviour? Thanks!
          I'll have to check again, but I had the impression it behaved differently for values coming from KNX...
            Could you show your Config of this test.
            I seem not to understand what your logic looks like.
            • J V
              • 386
              Config is quite complicated... it just seems that delay 1 is only updated it the analog value to which it is connected changes, not with the machine cycles. I need to check more as it may be some side effect.
              • J V
                • 386
                I cannot reprocude it anymore... now it behaves as one should expect, on all the values I tested yesterday... Weird...
                But at least the confirmation is that "cycles" in the delay documentation referes the cpu cycles.
