Tune IN bug? Missing radio stations
  • mariusmartocsan
    • 22.10.2020
    • 36
    Hello,
    I cant find some radio stations like Radio Zu, Kiss Fm, Europa Fm, all from Romania.
    On TuneIn app there are all the radio sations but not on my loxone app.
    I asked the team who did the install and they dont know how to fix this.
    How is tune in integrated? i cnat find any info on official docs, is trough API? is an account? as only spotify has the option to add account, for radio i see in app only on off.
    I tried on all categories to search the posts with no success.
    Also is there a way to set default radio stations on all rooms? as for now i see i need to go to each of 12 zone to manually chnage favorites.
    Thanks.
  • mariusmartocsan
    • 22.10.2020
    • 36
    IS this forum dead for support?
      • 7662
      No it is not..
      But you should give Hardware and Software informations like Type and Version etc
      Nobody is knowing what Hardware your talking about.
      • mariusmartocsan
        • 22.10.2020
        • 36
        Thank you for your reply, is LOXONE music server, the one that goes in the rack, it has the latest version of software.
        • mariusmartocsan
          • 22.10.2020
          • 36
            • 7662
            Then I have bad news for you, this is a well known issue. Some Logos and RadioStations are missing
            Loxone has an bad support for the MusicServer since they have the new AudioServer
            I have to look, but I sure there is a way to go to the LMS WebUI to do it indirectly from this side.
            I'm traveling these days but can give you further infos at Thursday evening.
            • mariusmartocsan
              • 22.10.2020
              • 36
              Thank you, they should offer support for all their products, because to the guys who installed they said is tune in problem... But the radio stations works well on tune in. Thank you.
                • 2605
                Try this link: http://<IP-of-Musicserver>:9000/Classic/ to get into the LMS Webinterface.
                • mariusmartocsan
                  • 22.10.2020
                  • 36
                  Player Model: SqueezeLite
                  Player Type: squeezelite
                  Firmware: v1.8.6-998_AB
                  Player IP Address: 192.168.0.78
                  Zuletzt geändert von mariusmartocsan; 09.03.2022, 08:20.
                  • mariusmartocsan
                    • 22.10.2020
                    • 36
                    Thanks, And now?
                    An updated version of Logitech Media Server is available and ready to install.
                    On some Linux distributions we provide an automatic download of Logitech Media Server update installers. These currently are available for .rpm and .deb based systems.
                    Your Logitech Media Server has downloaded the latest installer to the following location:
                    /var/lib/squeezeboxserver/cache/updates/logitechmediaserver_8.2.0_amd64.deb
                    Please execute the following steps to bring your Logitech Media Server installation up to date:
                    Log in to your server machine using your username and password.
                    Run the following command to execute the installer
                    sudo dpkg -i /var/lib/squeezeboxserver/cache/updates/logitechmediaserver_8.2.0_amd64.deb
                    More
                    WHERE DO I LOGIN?
                    Zuletzt geändert von mariusmartocsan; 09.03.2022, 08:46.
                    • mariusmartocsan
                      • 22.10.2020
                      • 36
                      Any update?
