set lowest possible target temperature for cooling
  • tstaels
    • 20.09.2021
    • 1
    After configuring my HVAC as per this Loxone webinar by Hugh Ewen ( https://www.youtube.com/watch?v=nZBxxT2OSQU ), I've noticed that the lowest target temperature that a user can set is 18°C.
    Cooling down to 18°C makes no sense in my opinion, so I would like to increase this to 21°C, but not seeing any way to influence this in the Intelligent Room Controller nor in the Climate controller.
    Put another way : how can i block users from setting a cooling temp lower than 21°C ?
    Does anyone have a clue for me ?
    Thanks,
    Tom.
    Zuletzt geändert von tstaels; 16.05.2024, 09:39.
  • SmartMastersAT
    • 20.10.2023
    • 72
    tstaels Hello, the HVAC controller unfortunately has no inputs for the target temperature or any way of adjusting the limits.
    May this would be a "feature request" you can place at Loxone...
    Deine zentrale Anlaufstelle für Support, technische Unterstützung, FAQs und Hilfestellungen - damit du dein LOXONE System optimal nutzen kannst.
    Search for " Ihre Feature-Anfrage"
