Connect to miniserver downloads project into editor
  • J V
    • 385
    Hello,
    When I connect to my miniserver (Loxone config and firmware 16.06.10), it downloads the current config into the editor, even if I have another project open.
    This prevents me from uploading a different config to the miniserver, as any connection I make loads the current config.
    How do I upload upload a different config file?
    (it is quite dramatic as I uploaded a small config to test something, and now want my full config back and cannot seem to get it)
    Thanks,
    Jörg
    Zuletzt geändert von J V; 29.06.2025, 16:24.
  • J V
    • 385
    Edit: still not solved..
    The fixed below worked for a moment, but now stopped working.
    Any suggestions?
    If the name (in Project properties, general) matches with the name of the project in the miniserver, it will not load the configuration into the editor.
    If the names do not match, it will ignore the open project and just load the miniserver's configuration in Loxone Config.
    (Quite annoying, as in project management, it only shows you the project name, not the file name... so you can't really distinguish different configurations that apply on the same miniserver, apart from their timestamp of last saving).
    Zuletzt geändert von J V; 30.06.2025, 11:48.
    • J V
      • 385
      Does anyone have any idea?
      At this point, I cannot upload my new configuration anymore as Loxone Config always downloads the project that is currently on the miniserver into the open project, overwriting my project.
      I have no way of uploading a new config into the miniserver... I spent a lot of time working offline on this new version, and now I have no way to upload it...
