Zigbee2Mqtt startup questions
  • BerndVP
    • 08.02.2026
    • 2
    Hi everyone,
    I'm new to the the LoxBerry family.
    So, I bought a Friendly NanoPi NEO3 (2GB) version back in March 2023.
    Since then I have LoxBerry running on this device.
    I want to start using it for connecting Zigbee protocol device into my Loxone setup.
    So I installed the Zigbee2Mqtt latest version on the Loxberry software, now when enabling the GUI interface for it, It can't view the GUI
    Any idea how to fix this ?
  • rickrode
    • vor einer Woche
    • 1
    I would first check the plugin logs and confirm that the frontend option is enabled in the Zigbee2Mqtt configuration file, because sometimes the service itself is running while the GUI stays inaccessible. It might also help to verify firewall settings or try accessing the interface directly through the device IP and port number. Setting up smart home integrations can definitely be tricky at first, but it is rewarding once everything works smoothly. After troubleshooting technical problems like this, I usually relax for a while with something fun like Ragdoll Hit.
