Virtual inputs not updating UI after config save
  • annasmith
    • 22.12.2025
    • 3
    Hello everyone,
    I am using the latest version of Loxone Config, and I have noticed an issue with virtual inputs in the user interface. After I save and transfer the configuration to the Miniserver, the virtual inputs work correctly in the logic, but their status in the app UI does not update until I restart the app or reload the project.
    Here is what I did:
    • I created several virtual inputs connected to a block that controls lighting scenes.
    • I successfully transferred the configuration to the Miniserver.
    • The logic responds immediately when a virtual input is triggered, but the UI tile still shows the previous state.
    Retro Bowl
    Has anyone experienced a delay or synchronization issue between virtual inputs and the UI after transferring a configuration? Is there a setting in Loxone Config or in the visualization that I might have missed?
    Thank!
    Zuletzt geändert von annasmith; 24.02.2026, 01:24.
  • novaevans
    • In den letzten 4 Wochen
    • 1
    • Click on the Virtual Input in the Periphery tree.
    • In the Properties window, look under the User Interface category.
    • Verify that Display is checked.
    • Check the Rating/Category—sometimes if an input is not assigned to a Room and Category, the UI refresh priority is lower.
