changing duration of presence 'off' leaving room and using 2C to end presence?
  • frederik.rooms
    • 22.03.2024
    • 6
    I almost got all the knowledge of Loxone function blocks and the settings but one is still unclear to me. nowhere in the documentation I can find a perfect explenation of this 'easy case':
    I got my presence block and my light block configured in a simple basic configuration. The Presence block has a presence sensor and is connected via Pc to the P of the light block. When you do that the Pto of the light block swithes to 0,01 and is not working since the presence block handles the presence.
    I guess the Pto works as follow: when you manualy disable presence (2C), the Pto starts counting the seconds when the light can be activated by the P input. But I just cannot find the same logic on the presence block. For example: when I leave the room and manually end presence via 2C I would like to switch it on again when I enter it 60 seconds later. But I simply cannot find this option. And somehow it must be different since I have cases in my home where the some rooms can be activated again very soon after a switch off by 2C in this room.
    Pet doesn't work either because it's 900 but after multiple times entering before and after 900 seconds it's not activated. The only reason I can find is this. Pet works but when you enter the room before 900 seconds it starts counting 900 seconds again till no movement in the 900 seconds is detected? But moving this to 60 would mean that if it detects nothing for 60 secons the room gets dark again... So why not having a different setting then?
  • Grestorn
    • 11.07.2022
    • 761
    There is one option I'm using: Don't connect the Presence sensor directly in the presence block. Instead, connect the presence out (P) of the presence sensor to the Act input of the presence block.
    This way, you can still configure the presence time in the presence sensor independently and make it shorter than the Pet of the sensor block. This way I achieved a way shorter "rentry" time after manually double clicking the room switch.
