text generator question
  • J V
    • 385
    Hello,
    I'm using the text generator block to build a string that is then directly passed to a virtual output (Txt is connected to VQ). This works fine:
    I set the inputs Vi, trigger Tr, and the string gets generated as I defined and the virtual output triggered with this string.
    However, after that, the Text Generator switches to the default value of 0, which again triggers the virtual output, this time with the string "0".
    Is there a way to avoid this?
    Can I connect the virtual output differently or is there an easy filter to put in between?
    Thanks!
    Jörg
