Loxconfig installs Teamviewer?
  • J V
    • 385
    Hello,
    Does anyone have an idea why Loxconfig installs Teamviewer?
    edit: not sure about version 8, but 7.4.4.14 installs it in the folder where loxone config is installed
    Thanks,
    Jörg
    Zuletzt geändert von J V; 09.08.2016, 11:17.
    It certainly shouldn't install teamviewer without permission. However, TeamViewer is used by Loxone to remotely solve customer problems. So, for example, if you open a problem report and they can't help you without accessing your PC remotely, they will ask you to install TeamViewer and setup a meeting.
    However, having LoxConfig install teamviewer just like that is strange. First time I hear about that.
    • J V
      • 385
      It does not show up in the startmenu, but there is an executable in the in the folder where Loxone Config is installed. I just noticed it when looking for something else.
      • Robert L.
        • 922
        in lox config go to "Diagnose->loxone support"
        will start this teamviewer
        i is not uncommon to also ship teamviewer with the product
          Yes, that makes sense. Shipping teamviewer with the product so you don't have to download it at short notice.
          • J V
            • 385
            Yes... ok. It makes sense. :-)
            I was a bit surprised to find Teamviewer, without any notification that it would be installed, so I mainly wanted to be sure that it is ok that it is there. If it is used in that way, it should not pose any security issue (not running normally). Would just be nice if it were mentioned somewhere at all.
            Thanks!
