How to fuse a RGBW tree extension
  • querex
    • 14.07.2020
    • 186
    When using a Meanwell 240W 24V DC PSU (NDR-240-24) for a Loxone RGBW extension...
    Do you guys place a 8A glass fuse before the RGBW extension?
    Or place a 2A glass fuse after each RGBW extension output?
    Or do you trust on the 10A short protection of the Meanwell PSU?​
    Many thanks.
    Some example of fuses after each RGBW output...
    Klicke auf die Grafik für eine vergrößerte Ansicht  Name: image.png Ansichten: 0 Größe: 701,6 KB ID: 425079
    Smart home: Miniserver Gen2, 2xRelay ext, 2xDimmer ext, 4xExtensions, Tree ext, Air base ext, RGBW dimmer tree, 13xTouch tree, 6xMotion sensor tree, 9xEsylux PD-C 360i 8UC, 15xValve actuator tree, 9xSmoke detector air, 4xSmart socket air, IR control air, Remote air, SDM630 modbus kWh
  • querex
    • 14.07.2020
    • 186
    Anyone?
    • querex
      • 14.07.2020
      • 186
      Guess I go for 4x 2A fuses on the output of the RGBW extension.
      And on the input, I will trust the Meanwell 10A overload / short protection.
      I will make sure the wiring on he RGBW extension input is done to handle more then 10A
      If someone still has some input / feedback, all welcome!
      • Inaxalers
        • 26.04.2024
        • 1
        Many thanks.
        • querex
          querex kommentierte
          Any advice? 😊
      • Boris
        • 23.01.2026
        • 1
        Hi, I'm making a new loxone setup (my first) and my idea was indeed to do the same thing. Per output of the RGBW dimmer, I will use 1 legrand fuse clamp (3245060371814) and a 5x20 glass fuse. My question is which fuse do you suggest? 2.5A or 2A? Fast/Slow?
