Hot water thermistor
    Installing a new system in a renovation project. Having a valiant boiler and cylinder (and 12 way manifolds). The plumbers are happy with 230v switched inputs for both heating demand and hot water demand, but suggested I hook up to the 2.7k thermistor for reading the current hot water temperature. Any ideas on this? I’ve found a small circuit on eBay for a 10k thermistor to 0-10v input, but not sure if can adapt it, or if any other options?
  • duncan
    • 328
    ive used one of the common 1-wire waterproof sensors pushed in to the temperature sensor tube of the cylinder - its direct readout of temperature unlike your thermistor solution
      Will have to have a look, do you have an eBay or other link for one. Wonder how easy it is to replace on the cylinder, on the plus point I’ve got 1-wire in for temperature sensors. First 4 lights connected.
      • duncan
        • 328
        ive attached the pdf for the cyclinders i used - item 5 on the diagram on page 2 shows the open empty thermostat tube/pocket - other cylinders will have something similar
        Find many great new & used options and get the best deals for DS18B20 WIRE Digital Thermometer in waterproof casing 18B20 at the best online prices at eBay UK! Free delivery for many products!
        there are loads to choose from
        my cyclinders have an external open tube into which a thermistor can be placed - just push in the metal sensor, i used a piece of foam jammed into the hole to keep it in place
          Thanks, got a pocket on the tank, hopefully get that in next week (along with all the valves on the manifold and the switched live demand lines to connect up).
