Ankündigung
Keine Ankündigung bisher.
memory not valid
  • Filter
  • memory not valid
    Hello, I made a program which runs fine for one or two times (after a reboot of miniserver), but then gets a memory not valid error. Does anybody see why?
    char *l;
    while (l==l)
    char *value;
    char *result = httpget("api.wunderground.com","/api/apikey/alerts/conditions/forecast/hourly/long%3ADL/pws%3A1/bestfct%3A1/q/gent,belgium.json");
    value = strstrskip(result, "city":"");
    char *substringg = calloc(1, 15);
    char *newsubstring= calloc(1, 150);
    strncpy(substringg,value,1);
    char *breakout = """;
    while (strcmp(substringg, breakout) != 0)
    //printf("substringresultn = %s", substringg );
    strcat(newsubstring, substringg);
    //printf("newsubstringresultn = %s", newsubstring );
    value = strstrskip(value,substringg);
    free(substringg);
    setoutputtext(0, newsubstring);
    free(value);
    free(substringg);
    free(result);
    free(newsubstring);
    free(breakout);
    sleeps(10);
    printf("weer opgehaald");
    Thanks.
  • #2
    There is a ready solution for querying the Wunderground weather data in this thread:
    https://www.loxforum.com/forum/faqs-...stein-abfragen
    • #3
      Yep, I saw that one, thanks, but it wasn't the service as such that was important for me, it was to learn the program block/code. It could have been any other service. I wonder why it works 2 times and then raises an error. When I reboot the miniserver it works again for 2 times.
      • #4
        Hi Prince,
        I am not sure, because I do not use pico c programs, but what I see is, that you allocate "char *result" but you never free it later on. So maybe there is a buffer overflow.
        I don´t know if the server has any garbage collector or automatic free for memory.
        Try free(result) in the last slope before "sleep"
        Loxone: 1x MS, 5 x Ext., 3 x Relay Ext., 1 x Dimmer Ext., 2 x 1-wire Ext., 1 x DMX Ext. 1 x TREE Ext. mehr kommt noch
        • Prince1001
          Prince1001 kommentierte
          Hi Simon, thanks for the feedback, but I free "result" (between free(substringg); and free(newsubstring). I tried to move it to just before "sleep" but same result.
      • #5
        there is a Free(result)
        i think the Problem is:
        free(substringg);
        • Prince1001
          Thanks Robert, I'll have a look at this.
      • #6
        My C skills seem to be also far away, but it might be a problem that you redefine variables on every loop (char *value; char *result ...)
        Possibly define the variables (pointers) outside the loop, and address them as normal variables/pointers inside.
          Nope, this is not the problem. Also C can handle this.
        • Robert L.
          Robert L. kommentierte
          wolltest du mir antworten?
          http://www.cplusplus.com/reference/cstring/strncpy/
          i still think Free the "substringg" is the problem
          strncpy expects a string that is at least num (+1?) long..
          Robert L. Nein, ich hab mich selbst korrigiert, das Wieder-initialisieren einer Variable in einer Schleife funktioniert auch in C.
      • #7
        char *l;
        while (l==l)
        of course is a strange construct, why not simply (1==1)?
        But it won't fix the error.
        • #8
          Another issue (that I don't know if PicoC handles different, but C++/C# needs) is escaping of quotes:
          --> value = strstrskip(result, "city\":\"");
          --> char *breakout = "\"";
          • Prince1001
            Hi Christian, I must have been lost in the copy but the quotes are escaped indeed
        • #9
          I deleted all the free(); things and now it works every time... (except free(result1))
          Finally I added a push button to it and this version has no memory issue.(copied from the example Christian pasted)
          int nEvents;
          float fEingangEins;
          char *host="api.wunderground.com";
          char *page="/api/xx/alerts/conditions/forecast/hourly/long%3ADL/pws%3A1/bestfct%3A1/q/gent,belgium.json";
          while(1==1){
              nEvents = getinputevent();  //Eingänge auslesen.
              if (nEvents & 0x18){               // Bitmaske für die Eingang.
                  fEingangEins = getinput(0); // Eingänge auf Veränderung prüfen, und ggf. Variabeln aktualisieren.
              if (fEingangEins != 0){
                  setoutputtext(0, "ophalen gemeente..");
                  fEingangEins = 0; // 0 setzten, damit der Abruf pro Flanke nur einmal erfolgt.
                  char *value;
                  char *result1 = httpget(host,page);
                  printf("t");
                  value = strstrskip(result1, "city\":\"");
                  free(result1);
                  char *newsubstring= calloc(1, 15);
                  sleeps(10);
