Ankündigung
Keine Ankündigung bisher.
Outside Air Quality in Loxone
  • Filter
  • Outside Air Quality in Loxone
    So there is a Polish company named Airly.eu that monitors air quality / air pollution in multiple locations in Poland and some parts of Europe (map link). They use mostly own air stations but also gather data from public / 3-party sensors. You might be lucky if you are located in a larger city in Germany, Netherlands, Belgium or Great Britain.
    They share all data they garther over a Restfull API for free with reasonable limits (1000 requests per day = max. one request every 1.5 minutes).
    I've created a simple Node-RED flow that finds the nearest sensor station relative to your GPS location and puts key measurements into MQTT broker:
    You may freely download this flow from here:
    https://flows.nodered.org/flow/8a80e...cd6d265f78e434
    Note: Before importing flow code, please add node-red-contrib-credentials module to your Node-RED pallete first.
    After you publish air measurements to a MQTT broker, you may ask your LoxBerry MQTT-Gateway plugin send it to Loxone Miniserver:
    Then it's pretty easy to set up some visualization for outside air quality data:
    And this is how it looks in Loxone app:
    Other possible uses of outside air quality data:
    • TTS with current quality level on leaving home pulse
    • bad air warning before taking up any sport activities (for example riding a bicycle)
    • push notification to do some actions on heavy air pollution (close windows, etc)
    • automatic action on heavy air pollution (stop ventilation, close down external blinds, etc)
    Have fun!
    Zuletzt geändert von TomekWaw; 05.Nov.2019, 17:07.
  • #2
    Thanks! Very nice addon
