LOXONE script with Hue Light http/1.1
    i have a Loxone that switch my light but after the update 1.23 it does not work any more.
    One such change is the new HTTP server component through which all commands are transferred. This new HTTP server is stricter in handling requests compared to the previous one, e.g. a HOST header field is required in all HTTP/1.1 request messages per RFC. This can impact your application due to non-functional behavioural changes or stricter handling of requests. We kindly would like to ask you to test this new release with your integration.
    can somebody help my with the right syntaxs
    sprintf(buffer, "PUT /api/%s/%s HTTP/1.1\r\nHost: %s\r\nConnection: keep-alive\r\nContent-Length: %d\r\n\r\n%s", USERNAME, selector, IP_ADDRESS, strlen(command), command)
    to set the groups light?
    i have now
    PUT /api/%s/%s HTTP/1.1\r\nHost:%s\r\n\r\n%s
    PUT /api/<username>/groups/8/action HTTP/1.1\r\nHost:192.168.20.30\r\n\r\n {"bri":71, "hue":0,"sat":255, "on":true}
    but stil not working ;-(
    it did work like a charm until the update 1.23
    Zuletzt geändert von Gast; 08.02.2018, 10:16.
    script.txt
    • Leigh
      • 730
      Just try this one...
      Der Vollständigkeit halber hier meine Software zum Anbinden einer HUE-Bridge an Loxone. Es können alle gängigen Lampen angesprochen werden (Dimmer, Ein/Aus,
      Ciao, Leigh
        Leigh,
        i try also your script, but Hue has changed something in the version 1.23 of the bridge, that's the problem
        Zuletzt geändert von Gast; 08.02.2018, 11:20.
          LOXONE script with Hue Light http/1.1 ->Log files
          I have make some log files.
          to do so i adding some code to the loxone , wat i notced is that now the light responce som times to the commands
          ------------ SEND-------------
          PUT /api/<adres>/groups/1/action HTTP/1.1
          Host: 192.168.20.30
          Content-Length: 72
          {"bri": 254, "hue": 21845, "sat": 252, "on": true, "transitiontime": 10}
          ------------ Recieved------------
          HTTP/1.1 200 OK
          Server: nginx
          Date: Fri, 09 Feb 2018 09:13:16 GMT
          Content-Type: application/json
          Connection: close
          Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0
          Pragma: no-cache
          Expires: Mon, 1 Aug 2011 09:00:00 GMT
          Access-Control-Max-Age: 3600
          Access-Control-Allow-Origin: *
          Access-Control-Allow-Credentials: true
          Access-Control-Allow-Methods: POST, GET, OPTIONS, PUT, DELETE, HEAD
          Access-Control-Allow-Headers: Content-Type
          [{"success":{"/groups/1/action/transitiontime":10}},{"success":{"/groups/1/action/on":true}},{"success":{"/groups/1/action/bri":254}},{"success":{"/groups/1/action/hue":21845}},{"success":{"/groups/1/action/sat":252}}]
