Am Ende muss ich wohl Loxone eine Mail schreiben, vielleicht suchen die mir das aus dem Forum raus ..
http://benutzername:passwort@ip-adresse
[HTML]
-- Setting up the connection data ROOMBA = Net.FHttp("111.222.333.444", 80)
-- geting info about specific device response = ROOMBA:GET("/roomba.json")
-- decoding json string to table extractedjson = json.decode(response)
-- Special usecase of [""] for json tree items with a - in it.
-- Be aware not to use a . infront of the [ !! -- The following JSON codes can be extracted -
- All that needs to be done is replace the rX value and rename the variable to whatever you liek -- -- "r0": "Bumps Wheeldrops" -- "r1": "Wall" -- "r2": "Cliff Left" -- "r3": "Cliff Front Left" -- "r4": "Cliff Front Right" -- "r5": "'Cliff Right'" -- "r6": "Virtual Wall" -- "r7": "Motor Overcurrents" -- "r8": "Dirt Detector - Left" -- "r9": "Dirt Detector - Right" -- "r10": "Remote Opcode" -- "r11": "Buttons" -- "r12": "Distance" -- "r13": "'Angle'" -- "r14": "Charging State" -- "r15": "Voltage" -- "r16": "Current" -- "r17": "Temperature" -- "r18": "Charge" -- "r19": "Capacity" motorovercurrents = extractedjson.response.r7.value distance = extractedjson.response.r12.value chargingstate = extractedjson.response.r14.value voltage = extractedjson.response.r15.value current = extractedjson.response.r16.value temperature = extractedjson.response.r17.value charge = extractedjson.response.r18.value capacity = extractedjson.response.r19.value -- output to resultline and globalvariable fibaro:log(charge) fibaro:setGlobal("roombacharge", charge); - See more at: http://www.roowifi.com/fibaro-home-center-2-plugin/#sthash.2u5lWDJK.dpuf
