Simple change value in Modbus
  • MickeyMiner
    • 18.04.2022
    • 13
    I have a Modbus analog sensor, and also a Modbus analog actor.
Ansichten: 30
Größe: 23,9 KB
    I want to make the value editable. What widget should I use between two of them to change the value of the temperature?
    The sensor has as display "Schieber/Slider", but it never appears as a slider.
    Thanks for your help.
    mm
    • 2744
    I would check the "Dimmer" or "EIB Dimmer" function Blocks for in between.
    They are highly configurable to fit the needs.
    • MickeyMiner
      • 18.04.2022
      • 13
      The Dimmer has only percentage (%) values (not absolutevalues ) and an On/Off button... not something you need when changing the temperature.
      Please Loxone, there must be some simple universal slider or gauge that change values between min and max with a certain step. Maybe with two alarms when the values rise or drop beyond some limits.
      (Just like there is a Switch, and the crooked Status/Radio elements)
      We can use it for setting temperature, pressure, speed, volume and many, many other things.
      • MickeyMiner
        • 18.04.2022
        • 13
        To make my invested energy useful for others, this is the final solution I am more or less satisfied with...
Ansichten: 20
Größe: 103,9 KB
