Classic water sensor (not Loxone air)
  • querex
    • 14.07.2020
    • 184
    As the 'Loxone Water Sensor Air' gets broken when it's submerged into water...
    I'm searching for alternatives for the classic wired water sensor which is discontinued by Loxone.
Ansichten: 791
Größe: 90,8 KB
    Smart home: Miniserver Gen2, 2xRelay ext, 2xDimmer ext, 4xExtensions, Tree ext, Air base ext, RGBW dimmer tree, 13xTouch tree, 6xMotion sensor tree, 9xEsylux PD-C 360i 8UC, 15xValve actuator tree, 9xSmoke detector air, 4xSmart socket air, IR control air, Remote air, SDM630 modbus kWh
  • hme0354
    • 06.07.2019
    • 1018
    looks like this is the one from loxone
    • querex
      • 14.07.2020
      • 184
      Thanks, indeed, looks the same and the price is OK.
      Just thinking, could it be an issue that the 24v is connected with the water when for example the basement is flooded?
      I guess the 24V could be an issue?
      But when another device (for example 230V) shorts on the water of the flooded basement, the 24V will raise to 230V (for a very short time), which can cause damage to the 24V loxone installation?
      Any advice or alternatives? All feedback is welcome!
      • dirkkleimann
        dirkkleimann kommentierte
        To avoid this, wouldn't be a relais a good choice?
      • querex
        querex kommentierte
        @dirkkleimann
        The sensor power still needs to be 24V in a relay set-up to power the coil.
        So situation stays the same?
      • dirkkleimann
        I am not an electrician, but when I understood correctly you'll try to avoid a damage on your Loxone components when there is a situation as described.
        By using a relais you can dived them into two circles. In case of short circuit you can protect the Loxone, isn't it?
    • hme0354
      • 06.07.2019
      • 1018
      how should a relay help here?
      • querex
        querex kommentierte
      Since years I use the Kemo Waterswitch (https://www.conrad.at/de/p/kemo-m158...BoCPe8QAvD_BwE) in my boiler room, and already had several real alarms.
      It has a relay, but is powered by 12VDC.
      The box is mounted 2 meter high, and the electrodes are shown in the picture
      Possibly nothing to install on a visible place, but works as expected.
      • querex
        querex kommentierte
        Interesting, thanks!
    • hme0354
      • 06.07.2019
      • 1018
      great looking system😆
      for me now I know that we are all cooking with water. even Christian Fenzl
