Der LB läuft auf dem Raspi.
Danke Grüße
exfat-fuse is already the newest version (1.2.5-2). You might want to run 'apt --fix-broken install' to correct these. The following packages have unmet dependencies: libraspberrypi-dev : Depends: libraspberrypi0 (= 1.20180417-1) but 1.20171029-1 is to be installed libraspberrypi-doc : Depends: libraspberrypi0 (= 1.20180417-1) but 1.20171029-1 is to be installed
sudo apt --fix-broken install
