Loxberry Webinterface "Apache2" läßt sich nicht starten "Segmentation Fault"
  • TimoC
    • 181
    mein Loxberry hat nach einem Reboot das Problem, dass sich der Apache2 nicht starten läßt. Somit habe ich keinen Zugriff auf das Webinterface.
    root@loxberry:/# /etc/init.d/apache2 start
    [....] Starting apache2 (via systemctl): apache2.serviceJob for apache2.service failed because the control process exited with error code.
    See "systemctl status apache2.service" and "journalctl -xe" for details.
     failed!
    root@loxberry:/#
    root@loxberry:/#
    root@loxberry:/# systemctl status apache2.service
    ● apache2.service - The Apache HTTP Server
       Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset: enabled)
      Drop-In: /etc/systemd/system/apache2.service.d
               └─privatetmp.conf
       Active: failed (Result: exit-code) since Sun 2018-10-14 13:15:11 CEST; 9s ago
      Process: 2445 ExecStart=/usr/sbin/apachectl start (code=exited, status=139)
    Oct 14 13:15:10 loxberry systemd[1]: Starting The Apache HTTP Server...
    Oct 14 13:15:11 loxberry apachectl[2445]: Segmentation fault
    Oct 14 13:15:11 loxberry apachectl[2445]: Action 'start' failed.
    Oct 14 13:15:11 loxberry apachectl[2445]: The Apache error log may have more information.
    Oct 14 13:15:11 loxberry systemd[1]: apache2.service: Control process exited, code=exited status=139
    Oct 14 13:15:11 loxberry systemd[1]: Failed to start The Apache HTTP Server.
    Oct 14 13:15:11 loxberry systemd[1]: apache2.service: Unit entered failed state.
    Oct 14 13:15:11 loxberry systemd[1]: apache2.service: Failed with result 'exit-code'.
    root@loxberry:/# journalctl -xe
    -- Defined-By: systemd
    -- Support: https://www.debian.org/support
    -- Unit apache2.service has begun starting up.
    Oct 14 13:14:58 loxberry apachectl[2373]: Segmentation fault
    Oct 14 13:14:58 loxberry apachectl[2373]: Action 'start' failed.
    Oct 14 13:14:58 loxberry apachectl[2373]: The Apache error log may have more information.
    Oct 14 13:14:58 loxberry systemd[1]: apache2.service: Control process exited, code=exited status=139
    Oct 14 13:14:58 loxberry systemd[1]: Failed to start The Apache HTTP Server.
    -- Subject: Unit apache2.service has failed
    -- Unit apache2.service has failed.
    -- The result is failed.
    Oct 14 13:14:58 loxberry systemd[1]: apache2.service: Unit entered failed state.
    Oct 14 13:14:58 loxberry systemd[1]: apache2.service: Failed with result 'exit-code'.
    Oct 14 13:15:02 loxberry CRON[2397]: pam_unix(cron:session): session opened for user loxberry by (uid=0)
    Oct 14 13:15:02 loxberry CRON[2398]: pam_unix(cron:session): session opened for user loxberry by (uid=0)
    Oct 14 13:15:02 loxberry CRON[2411]: (loxberry) CMD (cd / && run-parts --arg=cron=15min /opt/loxberry/system/cron/cron.15min > /dev/null 2>&1)
    Oct 14 13:15:02 loxberry CRON[2400]: pam_unix(cron:session): session opened for user loxberry by (uid=0)
    Oct 14 13:15:02 loxberry CRON[2399]: pam_unix(cron:session): session opened for user loxberry by (uid=0)
    Oct 14 13:15:02 loxberry CRON[2414]: (loxberry) CMD (cd / && run-parts --arg=cron=05min /opt/loxberry/system/cron/cron.05min > /dev/null 2>&1)
    Oct 14 13:15:02 loxberry CRON[2416]: (loxberry) CMD (cd / && run-parts --arg=cron=01min /opt/loxberry/system/cron/cron.01min > /dev/null 2>&1)
    Oct 14 13:15:02 loxberry CRON[2420]: (loxberry) CMD (cd / && run-parts --arg=cron=03min /opt/loxberry/system/cron/cron.03min > /dev/null 2>&1)
    Oct 14 13:15:02 loxberry CRON[2397]: pam_unix(cron:session): session closed for user loxberry
    Oct 14 13:15:02 loxberry CRON[2398]: pam_unix(cron:session): session closed for user loxberry
    Oct 14 13:15:02 loxberry CRON[2400]: pam_unix(cron:session): session closed for user loxberry
    Oct 14 13:15:02 loxberry CRON[2399]: pam_unix(cron:session): session closed for user loxberry
    -- Subject: Unit apache2.service has begun start-up
    Leider scheint auch kein error.log geschrieben zu werden unter: /opt/loxberry/log/system_tmpfs/apache2/
    Das Verzeichnis ist leer.
    Habe alle Startversuche mit root Rechten ausgeführt (kein sudo).
    Hat jemand eine Idee, wo ich mit Suchen anfangen kann. Der "Segmentation Fault" kann ja alles sein....
    • 6363
    Was hast Du denn zuletzt gemacht? Segmentation Fault klingt böse ... SD defekt?
    • TimoC
      • 181
      Die Vermutung hatte ich auch schon. Der Loxberry hat vor sich hin gewerkelt und ich musste ihn stromlos machen. Nach dem Reboot dann kein Zugriff mehr auf das Webinterface und ich bin auf die Suche gegangen. Die installierte HA-Bridge läuft sauber vor sich hin.
      Kann man die SD Karte irgendwie checken mit fsck oder ähnlichen?
        • 6363
        Fsck checkt das filesystem. Aber dafür muss das ja unmountet sein. Müsstest Du halt in einem anderen Linux machen
          • 5463
          fsck wäre erst einmal gut. Du könntest auch direkt in eine Shell booten und das Root-Filesystem von dort aus fsck'en. Google hilft wie das geht.
          Dann könntest Du auch mal probieren den Apache2 neu zu installieren über apt-get. Den genauen Aufruf auch mal googlen (irgendwas mit force muss rein, damit er trotz vorhandener Installation neu installiert).
          Nachdem Du den Apache2 neu installiert hast musst Du noch schauen, ob /etc/apache2 ein Symlink auf /opt/loxberr/system/apache2 ist. Ist es kein Symlink sondern ein Verzeichnis, dann musst Du noch /opt/loxberry/sbin/setenvironment.sh aufrufen.
          Oder Du installierst den Loxberry einfach neu - geht vermutlich schneller :-)
          • TimoC
            • 181
            Hier ein kurzes Update, damit spätere Leser evtl. auch was davon haben.
            Habe ein wenig getestet und ich vermute einen Hardware Defekt an der SD Karte.
            Da mir die weitere Fehlersuche zu mühsam ist, habe den Ansatz der Neuinstallation auf einer neuen SD Karte nun genutzt.
            Danke Svethi und Prof.Mobiliux für die Lösungsansätze.
