mein Loxberry hat nach einem Reboot das Problem, dass sich der Apache2 nicht starten läßt. Somit habe ich keinen Zugriff auf das Webinterface.
root@loxberry:/# /etc/init.d/apache2 start
[....] Starting apache2 (via systemctl): apache2.serviceJob for apache2.service failed because the control process exited with error code.
See "systemctl status apache2.service" and "journalctl -xe" for details.
failed!
root@loxberry:/#
root@loxberry:/#
root@loxberry:/# systemctl status apache2.service
● apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/apache2.service.d
└─privatetmp.conf
Active: failed (Result: exit-code) since Sun 2018-10-14 13:15:11 CEST; 9s ago
Process: 2445 ExecStart=/usr/sbin/apachectl start (code=exited, status=139)
Oct 14 13:15:10 loxberry systemd[1]: Starting The Apache HTTP Server...
Oct 14 13:15:11 loxberry apachectl[2445]: Segmentation fault
Oct 14 13:15:11 loxberry apachectl[2445]: Action 'start' failed.
Oct 14 13:15:11 loxberry apachectl[2445]: The Apache error log may have more information.
Oct 14 13:15:11 loxberry systemd[1]: apache2.service: Control process exited, code=exited status=139
Oct 14 13:15:11 loxberry systemd[1]: Failed to start The Apache HTTP Server.
Oct 14 13:15:11 loxberry systemd[1]: apache2.service: Unit entered failed state.
Oct 14 13:15:11 loxberry systemd[1]: apache2.service: Failed with result 'exit-code'.
root@loxberry:/# journalctl -xe
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- Unit apache2.service has begun starting up.
Oct 14 13:14:58 loxberry apachectl[2373]: Segmentation fault
Oct 14 13:14:58 loxberry apachectl[2373]: Action 'start' failed.
Oct 14 13:14:58 loxberry apachectl[2373]: The Apache error log may have more information.
Oct 14 13:14:58 loxberry systemd[1]: apache2.service: Control process exited, code=exited status=139
Oct 14 13:14:58 loxberry systemd[1]: Failed to start The Apache HTTP Server.
-- Subject: Unit apache2.service has failed
-- Unit apache2.service has failed.
-- The result is failed.
Oct 14 13:14:58 loxberry systemd[1]: apache2.service: Unit entered failed state.
Oct 14 13:14:58 loxberry systemd[1]: apache2.service: Failed with result 'exit-code'.
Oct 14 13:15:02 loxberry CRON[2397]: pam_unix(cron:session): session opened for user loxberry by (uid=0)
Oct 14 13:15:02 loxberry CRON[2398]: pam_unix(cron:session): session opened for user loxberry by (uid=0)
Oct 14 13:15:02 loxberry CRON[2411]: (loxberry) CMD (cd / && run-parts --arg=cron=15min /opt/loxberry/system/cron/cron.15min > /dev/null 2>&1)
Oct 14 13:15:02 loxberry CRON[2400]: pam_unix(cron:session): session opened for user loxberry by (uid=0)
Oct 14 13:15:02 loxberry CRON[2399]: pam_unix(cron:session): session opened for user loxberry by (uid=0)
Oct 14 13:15:02 loxberry CRON[2414]: (loxberry) CMD (cd / && run-parts --arg=cron=05min /opt/loxberry/system/cron/cron.05min > /dev/null 2>&1)
Oct 14 13:15:02 loxberry CRON[2416]: (loxberry) CMD (cd / && run-parts --arg=cron=01min /opt/loxberry/system/cron/cron.01min > /dev/null 2>&1)
Oct 14 13:15:02 loxberry CRON[2420]: (loxberry) CMD (cd / && run-parts --arg=cron=03min /opt/loxberry/system/cron/cron.03min > /dev/null 2>&1)
Oct 14 13:15:02 loxberry CRON[2397]: pam_unix(cron:session): session closed for user loxberry
Oct 14 13:15:02 loxberry CRON[2398]: pam_unix(cron:session): session closed for user loxberry
Oct 14 13:15:02 loxberry CRON[2400]: pam_unix(cron:session): session closed for user loxberry
Oct 14 13:15:02 loxberry CRON[2399]: pam_unix(cron:session): session closed for user loxberry
-- Subject: Unit apache2.service has begun start-up
Leider scheint auch kein error.log geschrieben zu werden unter: /opt/loxberry/log/system_tmpfs/apache2/
Das Verzeichnis ist leer.
Habe alle Startversuche mit root Rechten ausgeführt (kein sudo).
Hat jemand eine Idee, wo ich mit Suchen anfangen kann. Der "Segmentation Fault" kann ja alles sein....
