system_tmpfs is below limit of 5% discspace - Please reboot your LoxBerry. Wiki
  • MarkusR
    • 13.09.2016
    • 125
    Servus,
    Mein Loxberry macht alle ca. 7 Tage Probleme
    -> /opt/loxberry/log/system_tmpfs is below limit of 5% discspace (AVAL 0.0B/SIZE 200.0MB). Please reboot your LoxBerry. Wiki
    Nach einen Neustart geht wieder alles.
    Hier der Selbsttest und im Anhang die Plugins
    Tue Sep 29 2020 09:38:42 GMT+0200 (Mitteleuropäische Sommerzeit)
    <OK> LOXBERRY VERSION
    Current Version: 2.0.1.3 / No newer Release available.
    <INFO> LINUX KERNEL
    Linux loxberry 4.19.69-v7l+ #1256 SMP Fri Aug 30 16:37:01 BST 2019 armv7l GNU/Linux
    <INFO> SYSTEM ARCHITECTURE
    ARM / Raspberry Pi 4 Model B Rev 1.2
    <OK> CPU TEMPERATURE
    Current CPU Temperature is 48.7°C. Since last reboot the cpu never reached Raspberry's soft or critical temperature limit. This is fine.
    <OK> VOLTAGE
    No under-voltage nor system throttling nor capped ARM frequency detected. This is fine.
    <OK> ROOTFS
    RootFS is mounted ReadWrite. This is fine.
    <OK> ROOTFS FREE SPACE
    LoxBerry's RootFS has more than 10% free discspace (AVAL 21.9GB/SIZE 28.7GB).
    <ERROR> RAMDISCS FREE SPACE
    <ERROR> LOG DATABASE
    Could not init logfile database.Error executing the test:
    <OK> NOTIFICATION DATABASE
    Init notification database is ok. 6 notifications with 18 attributes stored. It contains 4 info and 0 error notifications.Database size is 28.0KB.
    <OK> MINISERVER ACCESS
    Degerndorf OK (no admin user).
    <OK> REBOOT REQUIRED
    LoxBerry and plugins do not require a reboot of your LoxBerry.
    <OK> PLUGIN LOGLEVELS
    No plugin is configured for loglevel DEBUG. (Some plugins may have it's own setting)
    ---- END of check results ----
    • 5101
    • MarkusR
      • 13.09.2016
      • 125
      Danke dir.
      im Anhang Screenshots
      Konnte damit nix finden, bzw. nur 2 von 200MB Belegt, vermutlich da vor 1 Stunde neu gestartet
      werde das gleich nochmal morgen versuchen.
      • MarkusR
        • 13.09.2016
        • 125
        2 Std. Später
        Der Plugin log von Weather4Loxone "deutlich" größer.
        Log Einstellung beim Plugin ist "Fehler"
        Ich melde mich morgen nochmal.
        • MarkusR
          • 13.09.2016
          • 125
          Jetzt sind 47MB Belegt, kann aber nicht finden wo (Siehe Screenshot)
          • MarkusR
            • 13.09.2016
            • 125
            Jetzt sind wieder 200MB belegt, aber nicht in den Verzeichnissen was in den Wiki Beitrag stehen siehe Anhang.
            Hab auch paar andere Ordner durchsucht und kann nix finden was soviel platz Braucht.
            Hab vor einiger zeit von den Pi2 auf den Pi4-B gewechselt mit den gleichen Image, liegt es evtl. daran?
              Nein, daran liegt’s nicht.
              Leider hab ich keine Zeit bis Dienstag. Wenn du bis Dienstag durchhältst (wieder mal rebooten), machen wir eine Remote Session, oder die Kollegen schauen zwischenzeitlich mal drauf.
          • MarkusR
            • 13.09.2016
            • 125
            Danke für die Rückmeldung.
            Ist nicht dringend meld dich einfach wenn du Zeit und Lust hast.
            reboot hab ich Grade gemacht.
            • Donny86
              Donny86 kommentierte
              Wenn ihr die Ursache gefunden habt, teile die Info bitte hier, da ich genau dasselbe Problem habe wie du.
            • MarkusR
              MarkusR kommentierte
              Klar mach ich. Was hast du für Plugins? Bzw. gleiche wie ich?
              Siehe ersten Beitrag
          • MarkusR
            • 13.09.2016
            • 125
            zur Info:
            Hab nach den Neustart noch ein Fehler gefunden siehe Anhang.
            LogBerry setswap
            19:17:12.953
            ERROR:
            Could not find all needed config files. Giving up.
            • Donny86
              • 30.06.2017
              • 111
Ansichten: 559
Größe: 113,6 KB
              Hier meine Plugins.
              • MarkusR
                • 13.09.2016
                • 125
                Falls es an einen Plugin Liegt dann vermutlich an.
                LoxBerry Backup, HaBridge, MiRobot2Lox oder Weather 4 Lox
                Die Haben wir beide.
                • MarkusR
                  Christian hat es sich gestern angeschaut.
                  scheint nicht an den vermuteten Plugins zu liegen (LoxBerry Backup, HaBridge, MiRobot2Lox oder Weather 4 Lox)
                  sondern an den CamSteam4Lox bzw. den Log Dateien von VLC-> festgestellt durch de Befehl "lsof | grep deleted"
                  Der Wiki Beitrag ist auch schon ergänzt https://www.loxwiki.eu/display/LOXBE...left+on+device
                  Ursache gefunden, dann ist die Lösung sich auch nicht weit
              • MarkusR
                • 13.09.2016
                • 125
                zur Info Das Loxberry Update 2.2.0 hat keine Veränderung gebracht, problem besteht weiterhin.
                  Ist ja auch ein Loxberry Update und kein Update des CamStream4Lox
                • MarkusR
                  Dachte ich mir schon, dass es da ein Update von de Plugin braucht.
                  wollte nur nochmal Rückmeldung geben.
