ERROR: Error on JSON expansion: Inappropriate ioctl for device
  • edipseamm
    • 03.02.2020
    • 60
    Since updating to v3.0.0.1 I have been getting this error from data from the unifi plugin from homekit that I run in a docker that passes statuses via mqtt and this is the only plugin that works to be able to send the doorbell is pressed in realtime. The loxberry and iobroker versions don't have this support.
    I seen from an older topic on this issue there was a fix but I'm hoping someone can help me understand where the issue is here.
    What is strange is the status is updated in the MQTT finder but not updated in the incomming data and then not passed to the miniserver
    Thanks in advance
    [SIZE=13px][COLOR=#8080ff][FONT=monospace]1:14:48.194 HTTP: Preparing input glow_A8032ADDC684_STATE_han_status (using cache): joined[/FONT][/COLOR][/SIZE]
    [SIZE=13px][COLOR=#8080ff][FONT=monospace]11:14:48.194 HTTP: Preparing input glow_A8032ADDC684_STATE_software (using cache): v1.8.13[/FONT][/COLOR][/SIZE]
    [SIZE=13px][COLOR=#000000][FONT=monospace]11:14:53.553 [COLOR=green][B]OK:[/B][/COLOR] MQTT IN: unifi/protect/E063DAEFF627/motion: false[/FONT][/COLOR][/SIZE]
    [SIZE=13px][COLOR=#8080ff][FONT=monospace]11:14:53.554 Expanding json message[/FONT][/COLOR][/SIZE]
    [SIZE=13px][COLOR=#000000][FONT=monospace]11:14:53.554 [COLOR=red][B]ERROR:[/B][/COLOR] Error on JSON expansion: Inappropriate ioctl for device[/FONT][/COLOR][/SIZE]
    [SIZE=13px][COLOR=#8080ff][FONT=monospace]11:14:53.554 All data filtered - skipping further processing of this message[/FONT][/COLOR][/SIZE]
    [SIZE=13px][COLOR=#000000][FONT=monospace]11:14:53.555 [COLOR=green][B]OK:[/B][/COLOR] MQTT IN: unifi/protect/E063DAEFF627/motion/smart/person: false[/FONT][/COLOR][/SIZE]
    [SIZE=13px][COLOR=#8080ff][FONT=monospace]11:14:53.555 Expanding json message[/FONT][/COLOR][/SIZE]
    [SIZE=13px][COLOR=#000000][FONT=monospace]11:14:53.556 [COLOR=red][B]ERROR:[/B][/COLOR] Error on JSON expansion: Inappropriate ioctl for device[/FONT][/COLOR][/SIZE]
    [SIZE=13px][COLOR=#8080ff][FONT=monospace]11:14:53.556 All data filtered - skipping further processing of this message[/FONT][/COLOR][/SIZE]
    [SIZE=13px][COLOR=#000000][FONT=monospace]11:14:57.645 [COLOR=green][B]OK:[/B][/COLOR] MQTT IN: glow/A8032ADDC684/SENSOR/electricitymeter: {"electricitymeter":{"timestamp":"2023-03-11T11:14:50Z","energy":{"export":{"cumulative":0.000,"units":"kWh"},"import":{"cumulative":30332.150,"day":10.755,"week":107.280,"month":249.369,"units":"kWh","mpan":"1591023835432","supplier":"Octopus Energy","price":{"unitrate":0.40600,"standingcharge":0.48380}}},"power":{"value":0.489,"units":"kW"}}}[/FONT][/COLOR][/SIZE]
    [SIZE=13px][COLOR=#8080ff][FONT=monospace]11:14:57.646 Expanding json message[/FONT][/COLOR][/SIZE]
    [SIZE=13px][COLOR=#8080ff][FONT=monospace]11:14:57.647 glow/A8032ADDC684/SENSOR/electricitymeter/electricitymeter_energy_import_supplier = Octopus Energy[/FONT][/COLOR][/SIZE]
    [SIZE=13px][COLOR=#8080ff][FONT=monospace]11:14:57.647 glow/A8032ADDC684/SENSOR/electricitymeter/electricitymeter_energy_import_mpan = 1591023835432[/FONT][/COLOR][/SIZE]
    [SIZE=13px][COLOR=#8080ff][FONT=monospace]11:14:57.647 glow/A8032ADDC684/SENSOR/electricitymeter/electricitymeter_energy_import_month = 249.369[/FONT][/COLOR][/SIZE]
    [SIZE=13px][COLOR=#8080ff][FONT=monospace]11:14:57.647 glow/A8032ADDC684/SENSOR/electricitymeter/electricitymeter_energy_import_price_unitrate = 0.406[/FONT][/COLOR][/SIZE]​
    I have to fix this in the MQTT Gateway.
    There was a change in the Perl json parser some time ago, so a simple message „false“ is now parsed as json, that my gateway does not expect.
    I‘ll try to get this, but I’m quite busy the next two weeks, therefore I cannot guarantee a quick fix.
    • edipseamm
      • 03.02.2020
      • 60
      Ok thanks. It took me some head-scratching to work out what was going on but at least you know the problem
      Thanks
      • rage302
        • 17.11.2017
        • 136
        ...okay this explains also my problem with the LWT from my Shellies -> https://www.loxforum.com/forum/proje...992#post383992
        Thank you for the Heads up! Christian Fenzl
        ...I will be patient.
        greetings rage
        • rage302
          • 17.11.2017
          • 136
          Hi Leute,
          ich bin mir ziemlich sicher, dass das Problem mit der LB V3.0.0.3 gefixt wurde.
          ....pretty sure that this Problem is fixed with LB V3.0.0.3.
          greetings rage
          • edipseamm
            • 03.02.2020
            • 60
            This is now not generating an error in the log but it is still not appearing in the incoming overview and thus not being sent to the mini-server
            Any help, please?
            • edipseamm
              • 03.02.2020
              • 60
              And here is all that shows in the incoming. The unifi/protect/E063DAEFF627/doorbell is missing
              • edipseamm
                • 03.02.2020
                • 60
                Actually I'm still getting ''
                ERROR:
                • rage302
                  • 17.11.2017
                  • 136
                  ERROR:
                  ...you are right, it has not been fixed properly. The workaround what helped me is to untick "Expand JSON data" in the Gateway settings.
                  greetings rage
                  • edipseamm
                    • 03.02.2020
                    • 60
                    Ahhh perfect. This has brought my water sensors and doorbell back online for now until there is a fix
                      I‘m currently working on this
                        If updating LoxBerry to „Latest Commit“, the problem should be solved.
                        You need to manually restart the Gateway by the button in the UI to restart the Gateway.
                        Christian
                        • edipseamm
                          • 03.02.2020
                          • 60
                          Hey Christan
                          Thanks a million for this. Updated ok but I'm away from home to test fully. But looks ok initally
                          • edipseamm
                            • 03.02.2020
                            • 60
                            I can confirm this is working correctly now. TY for the latest commit
                            • <Andreas>
                              • 07.03.2023
                              • 477
                              Works now fine for me
