LoxBerry goes Trixie (Debian 13) -- und neues Mitglied bei den Core-Entwicklern
Deine DNS Einstellungen funktionieren nicht. Er findet den GitHub Server nicht. Als root mit dietpi-config erstmal Dein Netzwerk in Orndung bringen. Dann nochmal probieren.🇺🇦 Hilfe für die Menschen der Ukraine: https://www.loxforum.com/forum/proje...Cr-die-ukraine
Fresh install of Trixie. Got this on rpi3. Network works fine besides this.
Code:[Wed Apr 29 09:08:06.657823 2026] [mpm_prefork:notice] [pid 854:tid 854] AH00163: Apache/2.4.66 (Debian) OpenSSL/3.5.5 configured -- resuming normal operations [Wed Apr 29 09:08:06.658089 2026] [core:notice] [pid 854:tid 854] AH00094: Command line: '/usr/sbin/apache2' pgrep: pattern that searches for process name longer than 15 characters will result in zero matches Try `pgrep -f' option to match against the complete command line. [Wed Apr 29 09:08:08 2026] index.cgi: "my" variable $output masks earlier declaration in same scope at /opt/loxberry/webfrontend/htmlauth/system/index.cgi line 104. [Wed Apr 29 09:08:08 2026] index.cgi: "my" variable $exitcode masks earlier declaration in same scope at /opt/loxberry/webfrontend/htmlauth/system/index.cgi line 105. [Wed Apr 29 09:08:08 2026] index.cgi: "my" variable $output masks earlier declaration in same scope at /opt/loxberry/webfrontend/htmlauth/system/index.cgi line 109. [Wed Apr 29 09:08:08 2026] index.cgi: "my" variable $exitcode masks earlier declaration in same scope at /opt/loxberry/webfrontend/htmlauth/system/index.cgi line 110. pgrep: pattern that searches for process name longer than 15 characters will result in zero matches Try `pgrep -f' option to match against the complete command line. [Wed Apr 29 09:08:13 2026] index.cgi: "my" variable $output masks earlier declaration in same scope at /opt/loxberry/webfrontend/htmlauth/system/index.cgi line 104. [Wed Apr 29 09:08:13 2026] index.cgi: "my" variable $exitcode masks earlier declaration in same scope at /opt/loxberry/webfrontend/htmlauth/system/index.cgi line 105. [Wed Apr 29 09:08:13 2026] index.cgi: "my" variable $output masks earlier declaration in same scope at /opt/loxberry/webfrontend/htmlauth/system/index.cgi line 109. [Wed Apr 29 09:08:13 2026] index.cgi: "my" variable $exitcode masks earlier declaration in same scope at /opt/loxberry/webfrontend/htmlauth/system/index.cgi line 110. [Wed Apr 29 09:08:17 2026] network.cgi: "my" variable $cfg masks earlier declaration in same scope at /opt/loxberry/webfrontend/htmlauth/system/network.cgi line 86. [Wed Apr 29 09:08:17 2026] network.cgi: Use of uninitialized value $wifiname in string ne at /opt/loxberry/webfrontend/htmlauth/system/network.cgi line 554. [Wed Apr 29 09:08:17 2026] network.cgi: Use of uninitialized value $wifiname in string ne at /opt/loxberry/webfrontend/htmlauth/system/network.cgi line 554. [Wed Apr 29 09:08:17 2026] network.cgi: Use of uninitialized value $wifiname in string ne at /opt/loxberry/webfrontend/htmlauth/system/network.cgi line 554. [Wed Apr 29 09:08:17 2026] network.cgi: Use of uninitialized value $wifiname in string ne at /opt/loxberry/webfrontend/htmlauth/system/network.cgi line 554. pgrep: pattern that searches for process name longer than 15 characters will result in zero matches Try `pgrep -f' option to match against the complete command line. pgrep: pattern that searches for process name longer than 15 characters will result in zero matches Try `pgrep -f' option to match against the complete command line. pgrep: pattern that searches for process name longer than 15 characters will result in zero matches Try `pgrep -f' option to match against the complete command line. pgrep: pattern that searches for process name longer than 15 characters will result in zero matches Try `pgrep -f' option to match against the complete command line. pgrep: pattern that searches for process name longer than 15 characters will result in zero matches Try `pgrep -f' option to match against the complete command line. pgrep: pattern that searches for process name longer than 15 characters will result in zero matches Try `pgrep -f' option to match against the complete command line. pgrep: pattern that searches for process name longer than 15 characters will result in zero matches Try `pgrep -f' option to match against the complete command line. pgrep: pattern that searches for process name longer than 15 characters will result in zero matches Try `pgrep -f' option to match against the complete command line. pgrep: pattern that searches for process name longer than 15 characters will result in zero matches Try `pgrep -f' option to match against the complete command line.
Solved internet problems with :
nano /etc/dnsmasq.d/99-upstream-dns.conf
server=8.8.8.8
server=1.1.1.1
Ctrl + O
Enter
Ctrl + X
systemctl restart dnsmasq
resolvconf -u
Works even after reboot
1 BildZuletzt geändert von BlackSoll; In den letzten 2 Wochen.Kommentar
Das Passwort hast du bei der Ersteinrichtung von Trixie vergeben: daher setzt der LoxBerry das Passwort nicht mehr.🇺🇦 Hilfe für die Menschen der Ukraine: https://www.loxforum.com/forum/proje...Cr-die-ukraine
Nein, hier geht es um das root Paswort. Das wird ausschließlich bei der Einrichtung von Zrixie gesetzt. Der LoxBerry macht am Root Passwort nichts mehr.🇺🇦 Hilfe für die Menschen der Ukraine: https://www.loxforum.com/forum/proje...Cr-die-ukraine
