LoxBerry V4.0.0 PRE-RELEASE
I just install latest commit and after a reboot when I hit the ip, the login form appears. I type username & pass and then just white page. SSH works, apache is running, audio server docker is running fine and players from Loxone app works. The loxberry ui is just blank. Eventually the browser goes to 504 gateway timeout. Can I do anything from ssh to restore or reinstall ? Running loxberry at a x86 with latest trixie !Zuletzt geändert von BlackSoll; vor 2 Tagen. -
Latest is for developers only.🇺🇦 Hilfe für die Menschen der Ukraine: https://www.loxforum.com/forum/proje...Cr-die-ukraine
I wanted to ask whether it will be possible to install it on Proxmox in the future. According to the guide here:
https://wiki.loxberry.de/installatio...xberry/proxmox
this procedure can no longer be used because the DietPi version it relies on is outdated.
i tried an update of a runnning loxberry to 4.0.0.7
pi4, dietpi 9.11.2, bullseye
got a couple of errors:
<INFO> Executing command 'python3 -m venv '/opt/loxberry/system/python_venv/mqttgateway''...
<ERROR> ERROR executing command - Exitcode 1
The virtual environment was not created successfully because ensurepip is not
available. On Debian/Ubuntu systems, you need to install the python3-venv
package using the following command.
apt-get install python3-venv
You may need to use sudo with that command. After installing the python3-venv
package, recreate your virtual environment.
Failing command: ['/opt/loxberry/system/python_venv/mqttgateway/bin/python3', '-Im', 'ensurepip', '--upgrade', '--default-pip']
<INFO> Executing command ''/opt/loxberry/system/python_venv/mqttgateway/bin/pip' install -q aiomqtt aiohttp'...
<ERROR> ERROR executing command - Exitcode 127
<INFO> Executing command 'chown -R loxberry:loxberry '/opt/loxberry/system/python_venv/mqttgateway''...
<OK> Command executed successfully. - Exitcode 0
<OK> MQTT Gateway venv created.
<OK> Update script /opt/loxberry/sbin/loxberryupdate/update_v4.0.0.6.pl finished.
17:55:51.939 <INFO> exec_perl_script /opt/loxberry/sbin/loxberryupdate/update_v4.0.0.6.pl release=v4.0.0.7 logfilename=/opt/loxberry/log/system/loxberryupdate/20260605_175546_413_update.log cron= updatedir=/tmp/loxberryupdate/mschlenstedt-Loxberry-9841038 with user - errcode 0
17:55:51.942 <OK> Update scripts executed successful.
17:55:51.942 <INFO> Migrating configuration settings from default config...
17:55:52.311 <OK> LoxBerry config settings updated successfully.
17:55:52.311 <INFO> Updating LoxBerry legacy templates...
17:55:53.123 <OK> LoxBerry legacy template successfully updated.
17:55:53.124 <INFO> Updating Skels for Logfolders...
17:55:54.092 <OK> Skels for Logfolders successfully updated.
17:55:54.093 <INFO> LoxBerry's config version is updated from v3.0.1.3 to v4.0.0.7
17:55:54.100 <INFO> Cleaning up temporary download folder
17:55:54.237 <INFO> All procedures finished.
17:55:54.258 <OK> Loxberry Update WAS SUCCESSFUL!
<LOGEND> LoxBerry Update processing finished.
<LOGEND> 05.06.2026 17:55:54 TASK FINISHED
i dont know whether this is important as everything seems to be workingKommentar
Pi-Version gemäss 'cat /proc/cpuinfo': Raspberry Pi 3 Model B Rev 1.2.
Distribution Debian 13 (trixie).
LB-Version 4.0.0.7
Backup/Restore funktioniert tip top. Allerdings erhalte ich beim öffnen des Widgets immer eine Fehlermeldung (siehe Anhang).
'showpitype' ergibt "nopi". Das löst wohl auch die Fehlermeldung aus. Wenn ich das richtig verstehe, erkennt das Script meine CPUs nicht korrekt. Auch bei den LB-System Informationen erhalte ich bei den CUPs 'unknown'.
Kann ich das bei mir korrigieren oder ist das ein bug?
Vielen Dank für deine rasche Rückmeldung. Anbei die gewünschten Ausgaben.Kommentar
Das ist wirklich interessant - DietPi erkannet den gar nicht als Raspberry. Unser eigenes Skript showpitype ja auch nicht (die Erkennungen hatte ich auch mal irgendwoher "geklaut").
Das solltest Du mal mit der Ausgabe von cat /proc/cpuinfo an DietPi als Issue melden: https://github.com/MichaIng/DietPi/issuesCode:cat /boot/dietpi/.hw_model root@loxberry11:~# cat /boot/dietpi/.hw_model G_HW_MODEL=22 G_HW_MODEL_NAME='Generic Device (aarch64)' G_HW_ARCH=3 G_HW_ARCH_NAME='aarch64' G_HW_CPUID=0 G_HW_CPU_CORES=4 G_DISTRO=8 G_DISTRO_NAME='trixie' G_ROOTFS_DEV='/dev/mmcblk0p2' G_HW_UUID='b9605029-bdf1-435f-8eef-5cb28740145f'
im not sure if the fix is already in the latest dev - i tried again, same pi4, diepi 9 / bullseyei tried an update of a runnning loxberry to 4.0.0.7
17:55:51.939 exec_perl_script /opt/loxberry/sbin/loxberryupdate/update_v4.0.0.6.pl release=v4.0.0.7 logfilename=/opt/loxberry/log/system/loxberryupdate/20260605_175546_413_update.log cron= updatedir=/tmp/loxberryupdate/mschlenstedt-Loxberry-9841038 with user - errcode 0
17:55:51.942 Update scripts executed successful.
17:55:51.942 Migrating configuration settings from default config...
17:55:52.311 LoxBerry config settings updated successfully.
17:55:52.311 Updating LoxBerry legacy templates...
17:55:53.123 LoxBerry legacy template successfully updated.
17:55:53.124 Updating Skels for Logfolders...
17:55:54.092 Skels for Logfolders successfully updated.
17:55:54.093 LoxBerry's config version is updated from v3.0.1.3 to v4.0.0.7
17:55:54.100 Cleaning up temporary download folder
17:55:54.237 All procedures finished.
17:55:54.258 Loxberry Update WAS SUCCESSFUL!
E: Failed to fetch https://deb.debian.org/debian-securi...11u3_arm64.deb 404 Not Found [IP: 151.101.2.132 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
CRITICAL: Error installing python3-venv - Error 100
INFO: Creating MQTT Gateway venv at /opt/loxberry/system/python_venv/mqttgateway...
INFO: Executing command 'python3 -m venv '/opt/loxberry/system/python_venv/mqttgateway''...
ERROR: ERROR executing command - Exitcode 1
INFO: Executing command 'chown -R loxberry:loxberry '/opt/loxberry/system/python_venv/mqttgateway''...
OK: Command executed successfully. - Exitcode 0
ERROR: Update script /opt/loxberry/sbin/loxberryupdate/update_v4.0.0.6.pl finished with errors.
16:21:59.513 INFO: exec_perl_script /opt/loxberry/sbin/loxberryupdate/update_v4.0.0.6.pl release=v4.0.0.9 logfilename=/opt/loxberry/log/system/loxberryupdate/20260606_162147_017_update.log cron= updatedir=/tmp/loxberryupdate/Loxberry-master with user - errcode 2
16:21:59.513 ERROR: Update-Script update_v4.0.0.6 returned errorcode 2. Despite errors loxberryupdate.pl will continue.
16:21:59.514 INFO: Setting update script update_v4.0.0.6 as failed in general configuration.
16:21:59.514 INFO: Script version: v4.0.0.8
16:21:59.514 INFO: Running update script for v4.0.0.8...
i tried running "apt-get install python3-venv" as root from a telnet session and get a lot of 404 not found errors
After this operation, 458 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Err:1 https://deb.debian.org/debian-security bullseye-security/main arm64 python 3.9-dev arm64 3.9.2-1+deb11u3
404 Not Found [IP: 151.101.194.132 443]
Err:2 https://deb.debian.org/debian-security bullseye-security/main arm64 libpyt hon3.9-dev arm64 3.9.2-1+deb11u3
Err:3 https://deb.debian.org/debian-security bullseye-security/main arm64 libpyt hon3.9 arm64 3.9.2-1+deb11u3
Err:4 https://deb.debian.org/debian-security bullseye-security/main arm64 python 3.9 arm64 3.9.2-1+deb11u3
Err:5 https://deb.debian.org/debian-security bullseye-security/main arm64 libpyt hon3.9-stdlib arm64 3.9.2-1+deb11u3
Err:6 https://deb.debian.org/debian-security bullseye-security/main arm64 python 3.9-minimal arm64 3.9.2-1+deb11u3
Err:7 https://deb.debian.org/debian-security bullseye-security/main arm64 libpyt hon3.9-minimal arm64 3.9.2-1+deb11u3
Err:8 https://deb.debian.org/debian-security bullseye-security/main arm64 python 3.9-venv arm64 3.9.2-1+deb11u3
E: Failed to fetch https://deb.debian.org/debian-securi...ates/main/p/py thon3.9/python3.9-dev_3.9.2-1%2bdeb11u3_arm64.deb 404 Not Found [IP: 151.101.1 94.132 443]
E: Failed to fetch https://deb.debian.org/debian-securi...ates/main/p/py thon3.9/libpython3.9-dev_3.9.2-1%2bdeb11u3_arm64.deb 404 Not Found [IP: 151.10 1.194.132 443]
E: Failed to fetch https://deb.debian.org/debian-securi...ates/main/p/py thon3.9/libpython3.9_3.9.2-1%2bdeb11u3_arm64.deb 404 Not Found [IP: 151.101.19 4.132 443]
E: Failed to fetch https://deb.debian.org/debian-securi...ates/main/p/py thon3.9/python3.9_3.9.2-1%2bdeb11u3_arm64.deb 404 Not Found [IP: 151.101.194.1 32 443]
E: Failed to fetch https://deb.debian.org/debian-securi...ates/main/p/py thon3.9/libpython3.9-stdlib_3.9.2-1%2bdeb11u3_arm64.deb 404 Not Found [IP: 151 .101.194.132 443]
E: Failed to fetch https://deb.debian.org/debian-securi...ates/main/p/py thon3.9/python3.9-minimal_3.9.2-1%2bdeb11u3_arm64.deb 404 Not Found [IP: 151.1 01.194.132 443]
E: Failed to fetch https://deb.debian.org/debian-securi...ates/main/p/py thon3.9/libpython3.9-minimal_3.9.2-1%2bdeb11u3_arm64.deb 404 Not Found [IP: 15 1.101.194.132 443]
E: Failed to fetch https://deb.debian.org/debian-securi...ates/main/p/py thon3.9/python3.9-venv_3.9.2-1%2bdeb11u3_arm64.deb 404 Not Found [IP: 151.101. 194.132 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-mis sing?
Zuletzt geändert von duncan; vor 2 Stunden.Kommentar
after a bit of reading it seems the following is necessary on this older version of dietpi
After adding deb http://security.ubuntu.com/ubuntu focal-security main universe in /etc/apt/sources.list,
run apt update
then the 4.0.0.9 update script rins without errorsKommentar
