Plugin: PV Solcast (Forecast für PV Anlagen)
  • Houseruckiii
    • 31.10.2016
    • 84
    #436
    Tach, die Abfrage geht bei mir auch seit ~Freitag nicht mehr. Habe keine Änderungen am Loxberry/System gemacht.
    Habe gestern im Plugin den Debug eingeschaltet, hier der Log der Anlage 1:
    2025-11-15 10:00:02 - Hourly-Cron, Hour not set for Request - System 1
    2025-11-15 11:00:02 - Hourly-Cron, Hour not set for Request - System 1
    2025-11-15 12:00:02 - Hourly-Cron, Hour not set for Request - System 1
    2025-11-15 13:00:02 - Hourly-Cron, Hour not set for Request - System 1
    2025-11-15 14:00:02 - Hourly-Cron, Hour not set for Request - System 1
    2025-11-15 15:00:02 - Hourly-Cron, Hour not set for Request - System 1
    2025-11-15 16:00:02 - Hourly-Cron, Hour not set for Request - System 1
    2025-11-15 17:00:02 - Request by cron - System 1
    2025-11-15 17:00:02 - "Code: 429 \/ Client Error: Too Many Requests"
    2025-11-15 17:00:02 - {"url":"https:\/\/api.solcast.com.au\/rooftop_sites\/5fdc-XXXX-XXXX-35a1\/forecasts?format=json&api_key=XXXX","content_type":null,"http_code":429,"header_size":290,"request_size":151,"filetime":-1,"ssl_verify_result":0,"redirect_count":0,"total_time":0.139897,"namelookup_time":0.07355,"connect_time":0.0903,"pretransfer_time":0.124972,"size_upload":0,"size_download":0,"speed_download":0,"speed_upload":0,"download_content_length":0,"upload_content_length":-1,"starttransfer_time":0.139868,"redirect_time":0,"redirect_url":"","primary_ip":"65.9.175.103","certinfo":[],"primary_port":443,"local_ip":"192.168.5.78","local_port":40308,"http_version":3,"protocol":2,"ssl_verifyresult":0,"scheme":"HTTPS","appconnect_time_us":124721,"connect_time_us":90300,"namelookup_time_us":73550,"pretransfer_time_us":124972,"redirect_time_us":0,"starttransfer_time_us":139868,"total_time_us":139897}
    2025-11-15 18:00:02 - Hourly-Cron, Hour not set for Request - System 1
    2025-11-15 19:00:01 - Hourly-Cron, Hour not set for Request - System 1
    2025-11-15 20:00:02 - Hourly-Cron, Hour not set for Request - System 1
    2025-11-15 21:00:02 - Hourly-Cron, Hour not set for Request - System 1
    2025-11-15 22:00:02 - Hourly-Cron, Hour not set for Request - System 1
    2025-11-15 23:00:02 - Hourly-Cron, Hour not set for Request - System 1
    2025-11-16 00:00:02 - Hourly-Cron, Hour not set for Request - System 1
    2025-11-16 01:00:02 - Hourly-Cron, Hour not set for Request - System 1
    2025-11-16 02:00:02 - Hourly-Cron, Hour not set for Request - System 1
    2025-11-16 03:00:02 - Hourly-Cron, Hour not set for Request - System 1
    2025-11-16 04:00:01 - Request by cron - System 1
    2025-11-16 04:00:02 - "Code: 429 \/ Client Error: Too Many Requests"
    2025-11-16 04:00:02 - {"url":"https:\/\/api.solcast.com.au\/rooftop_sites\/5fdc-XXXX-XXXX-35a1\/forecasts?format=json&api_key=XXXX","content_type":null,"http_code":429,"header_size":290,"request_size":151,"filetime":-1,"ssl_verify_result":0,"redirect_count":0,"total_time":0.149695,"namelookup_time":0.07797,"connect_time":0.097835,"pretransfer_time":0.12994,"size_upload":0,"size_download":0,"speed_download":0,"speed_upload":0,"download_content_length":0,"upload_content_length":-1,"starttransfer_time":0.149662,"redirect_time":0,"redirect_url":"","primary_ip":"65.9.175.98","certinfo":[],"primary_port":443,"local_ip":"192.168.5.78","local_port":34708,"http_version":3,"protocol":2,"ssl_verifyresult":0,"scheme":"HTTPS","appconnect_time_us":129816,"connect_time_us":97835,"namelookup_time_us":77970,"pretransfer_time_us":129940,"redirect_time_us":0,"starttransfer_time_us":149662,"total_time_us":149695}
    2025-11-16 05:00:02 - Hourly-Cron, Hour not set for Request - System 1
    2025-11-16 06:00:03 - Hourly-Cron, Hour not set for Request - System 1
    • Johny
      • 04.09.2016
      • 143
      #437
      Habe auch keine Aktualisierung mehr.
        • 7599
        #438
        Ich habe absichtlich das Plugin heute Nacht nichts abrufen lassen. Trotzdem kommen to may requests.
        Dann habe ich meinen Reserve Key der nur für Entwicklung genutzt wird herangezogen und das gleiche wieder...
        Mal schauen was sie da wieder geamcht haben.
        Ich habe übrigens bis gestern noch Updates erhalten.
          • 7599
          #439
          Ich habe im Anhang eine Vorgänger-Version hochgeladen.
          Hier sind wieder alle Werte Azimut etc einzustellen, bei mir geht es damit wieder.
          • hme0354
            hme0354 kommentierte
            geht bei dir jetzt weiterhin die alte Version?
            Lustigerweise ja.
            Es scheinen jetzt wieder beide Versionen zu gehen Mit Roof ID und mit einzelnen Daten.
        • Johny
          • 04.09.2016
          • 143
          #440
          Es scheint wieder zu funktionieren. Ich habe um 17:00 aktualisierte Werte erhalten.
          • Houseruckiii
            Houseruckiii kommentierte
            Ja genau wie bei mir, hatte um 17Uhr auch wieder neue Werte bekommen.
        • DrS332
          • 25.07.2020
          • 15
          #441
          Bei mir geht es auch wieder. Habe nicht gemachte - nur gewartet.
          • hakkun
            • 16.07.2019
            • 49
            #442
            Ich habe eine Frage zu dem parameter: solcast/1/total_td_kw
            Wieso ist dieser Wert veränderlich, d.h. er nimmt stündlich ab bei jeder Abfrage? Zeigt der Wert nicht den erwarteten Forecast in kWh für den aktuellen Tag? Oder ist das der Forecast bis 00:00 (Tagesende?)
              Forecast Today...
              Klar nimmt der ab, es werden nach jedem Abruf die Werte berechnet. Also ist die abgelaufene Zeit nicht mehr als Wert vorhanden.
              Mich interessiert ja nicht was schon war, sondern was noch kommt (Forecast).
              Wenn du in MQTT schaust, sollte es einen Werte geben der mit mn anfängt.
              midnight sagt die einen Werte der zu der Uhrzeit als forecast für den ganzen Tag gesehen wird. Der ändert sich auch erst wieder um Mitternacht.
          • Velbau
            • 23.08.2017
            • 5
            #443
            Guten Abend und ein gutes, hoffentlich friedliches neues Jahr.
            Vielen herzlichen Dank an alle für die hervorragende Arbeit hier in den Foren sowie ganz besonders bei LoxBerry.
            Ich habe versucht, mein Problem mithilfe der ausführlichen Anleitungen/ Forumbeiträge zu lösen – leider ohne Erfolg.
            Ausgangslage
            Ich habe das Solcast-Plugin auf einem LoxBerry V3.0.1.3 installiert. Loxone MS Gen 1,
            Aktueller Stand:
            • MQTT ist gemäß Anleitung konfiguriert
            • Keine Fehlermeldungen im Plugin
            • Im Incoming Overview des Plugins werden korrekte Solcast-Werte angezeigt (z. B. 0,33)
            • Das Plugin scheint insgesamt sauber zu laufen
            Problem
            In der Loxone Config (aktuellste Version) habe ich einen Virtuellen Eingang angelegt:
            • Bezeichnung per Copy & Paste aus dem Miniserver Virtual Input
            • Digitaler Eingang deaktiviert
            • Eingang wird ausschließlich als Status verwendet
            In der Loxone App sehe ich z. B. folgenden Wert: solcast_1_hourly_tm_w_12 = 0.00
            Dieser Wert bleibt dauerhaft bei 0.00, obwohl im Incoming Overview des Plugins der korrekte Wert (0,33) angezeigt wird.
            Im Loxone HTML Monitor scheinen keine Werte vom MQTT Gateway an den Miniserver gesendet zu werden.
            Meine Fragen:
            • Mache ich hier grundsätzlich etwas falsch?
            • Muss der Virtuelle Eingang anders konfiguriert werden?
            Vielen herzlichen Dank für eure Unterstützung!
            • Jan W.
              Jan W. kommentierte
              Den MS hattest Du nach Anlegen des virtuellen Eingangs sicherlich neu gestartet. Da MQTT nur geänderte Werte schreibt, benötigt das MQTT Gateway des Loxberrys einen Trigger bei Neustart des MS, so dass ALLE Werte erneut an den MS gesendet werden, siehe https://wiki.loxberry.de/konfigurati...aten_forcieren
              Zuletzt geändert von Jan W.; 06.01.2026, 21:14.
          • Velbau
            • 23.08.2017
            • 5
            #444
            Vielen herzlichen Dank, es hat geklappt.
            • Tommes78
              • 24.09.2015
              • 681
              #445
              Hi, habe neuerdings das Problem das die Werte nicht mehr refresht werden. Habe ins Logfile geschaut, da steht nun die Meldung: Too Many Requests.
              Wenn ich die URL vom Solcast manuell aufrufe bekomme ich Werte zurück. Dann kann es ja eigentlich nicht an Solcast liegen. Lief auch lange problemlos und
              geändert habe ich eigentlich nichts. Jemand ne Idee ??
              2026-03-22 12:00:03 - Request by cron - System 1
              2026-03-22 12:00:04 - "Code: 429 \/ Client Error: Too Many Requests"
              2026-03-22 12:00:04 - {"url":"https:\/\/api.solcast.com.au\/rooftop_sites\/e884-584f-066a-bf86\/forecasts?format=json&api_key=-wHXXXXXXXXXQzeTfZkA4_MscMVljF6","content_type":nu ll,"http_code":429,"header_size":289,"request_siz e ":151,"filetime":-1,"ssl_verify_result":20,
              • Joneass
                • 11.04.2021
                • 11
                #446
                Hatte vor/seit über einem Jahr das gleiche Problem!
                https://www.loxforum.com/forum/projektforen/loxberry/plugins/307349-plugin-pv-solcast-forecast-für-pv-anlagen?p=452233#post452233
                mache es seit dem über nodered
                Zuletzt geändert von Joneass; In den letzten 4 Wochen.
                • Johny
                  • 04.09.2016
                  • 143
                  #447
                  habe in den letzten Tagen auch immer mal Aussetzer. So heute. Aber im laufe des Tages ging es dann wieder.
                  • buki
                    buki kommentierte
                    Same here. Ganzen tag keine daten erhalten, um 18:00 ging es wieder.
                  • 7599
                  #448
                  Man, da kommen einen Tag mal keine Daten, und schon ein Post hier...
                  Schon mal daran gedacht das es an Solcast liegt
                  Joneass auch damals war es ein Problem bei Solcast, ich habe den Fehler gesucht, und plötzlich ging es wieder von allein.
                  • Noschvie
                    Noschvie kommentierte
                    Sehe es doch als Kompliment: dein Plugin ist nützlich und unentbehrlich!
                • Joneass
                  • 11.04.2021
                  • 11
                  #449
                  Ich habe hier nur auf einen Post geantwortet!
                  Mein Problem bestand damals nicht nur an einem Tag sondern generell beim zweiten call der Abfrage aus dem Plug In.
                  ich habe das Problem damals umgangen und den call aus Loxone implementiert…. es läuft seitdem so stabil…
                  EDIT:
                  Gerade nochmal geschaut, (war ja auch schon lange her)
                  bei mir läuft es doch wieder standardmäßig aus dem PlugIn …. Also SORRY ich verwende das Plug In PROBLEMLOS!
                  • Gerrit
                    • 956
                    #450
                    Zwei Featurewünsche bzw. Ideen:
                    • Ich benutze das Plugin um zu entscheiden, ob man den Speicher von 1-5 Uhr mit günstigem Strom füllen sollte (EnWG 14a Modul 3). Vor 1 Uhr gibt es dabei nur den Request um Mitternacht. Falls der aus welchen Gründen auch immer fehlschlägt, gibt es aktuell keine Möglichkeit einen weiteren bis 1 Uhr einzurichten. Deshalb wäre Idee für den Cron Job die Konfigurationsmöglichkeit auf alle 30min und jede Stunde des Tages zu erweitern. Aktuell kann man nur ab 4 Uhr einstellen (hatte das Problem schon deshalb)
                    • Als weiteren Ausfallschutz habe ich noch https://www.forecast.solar/ über iobroker angebunden. Vllt wäre das für dieses Plugin auch interessant noch andere Anbieter mit aufzunehmen
                    Zuletzt geändert von Gerrit; In den letzten 4 Wochen.
                    • Noschvie
                      forecast.solar scheint von einer Einzelperson betrieben zu werden, was ja grundsätzlich nichts schlechtes ist. Viel wichtiger ist eine hohe Verfügbarkeit des Service und die Zuverlässigkeit des Outputs.
