Plugin: LoxBerry Poolex (Poolstar) Wärmepumpen
    • 5374
    Nein, "running" betrifft das Plugin. Wenn die Bridge läuft, ist der Wert 1, sonst 0. "hvac_mode" ist quasi Power: 1 heisst WP ist eingeschaltet, 0 heisst "aus". Den kannst Du auch schreiben.
    • Donny86
      Donny86 kommentierte
      Ich versuche den havac Mode über das topic Set command und mittels des Energiemanagers zu schalten. Set Command 1,0 schaltet die Pumpe auch einwandfrei aus, Set Command 1,1 jedoch nicht an.
      Weißt jmd wo der Fehler ist?
      Danke und viele Grüße
      Anstelle 0 und 1 nimm mal true und false
  • Felda1974
    • 14.06.2022
    • 4
    Hello again. Thank you for your reaction and answer.
    I would like to ask you if is possible to add another model of pool heat pump to your plugin. I hope it can be hepful for another users of Fairland pool heating pump.
    I already prepared a "device file" (please find attached) called fairland.json.
    I tried to get a status with values and this is a result of data:
    Polling local devices... ................. - [On] - DPS: {'1': True, '102': 23, '103': True, '104': 100, '105': 'warm', '106': 31, '107': 18, '108': 40, '115': 0, '116': 0, '117': True}
    Thank you for your help
    Have a nice weekend
    Marek
      • 5374
      I can add this one. But I currently working on a Tuya Plugin which supports all kind of devices and grep this "mapping/translation" files by it's own from the Tuya servers. This new plugin will work with all tuya devices.
      • Felda1974
        • 14.06.2022
        • 4
        This is great news!!! :-) Thank you again very much for your work!
        Any idea when your new plugin will be available?
        If it's not such a big and difficult job for you, I would appreciate if you add the Fairland model to your existing plugin.
        I would like to use this functionality for this summer season.
        Another option (if you would be so kind) is to instruct me how to add manyually (myself) to your current version. I tried that, but didn't know what (which files) needed to be edited.
        Thank you very much
        Marek​
          I am currently not at home, but can check when I am back. But you can also read the status_raw topic instead of status and use the IDs instead of the names.
      • FRECH
        • 07.08.2017
        • 274
        Weiß jemand ob und ggf. wie man den Heizmodus bei der Poolex Silverline zB auf Eco ändern kann?
        Danke und beste Grüße
        • FRECH
          • 07.08.2017
          • 274
          Hallo!
          Diese Bridge ist echt genial!! Danke dafür...
          Vlt ist diese Erkenntnisse auch andere auch interessant, oder jemand hatte dieses Verhalten schon...
          1. Zeit zwischen Loxone und MQTT berücksichtigen
          Die Bridge läuft... (siehe violette Markierung)
          Der Timestamp im MQTT ist aktueller als der Wert in der Loxone...
          In meinem Fall sieht man den Fehler in der Loxone (rot- Wert 256) und im MQTT ist der Wert 0 (kein Fehler)
          Unterschied bei der Aktualisierung 487 Sekunden --> bischen mehr als 8min.
          Kann man eine Aktualisierung irgendwie anstoßen? (Warum: die WP läuft schon, und die Loxone versucht noch den Fehler zu beheben)
Ansichten: 329
Größe: 244,3 KB
          2. Was der Wert poolex_set_command macht, ist mir noch nicht ganz klar.
          3. Wann läuft die Poolex Silverline FI?
          Ich glaub wenn poolex_status_dps_hvac##_mode = 1 & kein Fehler vorhanden ist...
          beste Grüße FRECH
            • 5374
            Die Aktualisierung erfolgt sofort und permanent ohne Verzögerung. Aber nur, wenn sich eine erst ändert. Daher geht es auch nicht das anzustoßen.
            zu 2: an das topic werden die Kommandos gesendet.
            zu 3: korrekt
            • FRECH
              FRECH kommentierte
              Danke!
              Weißt du vlt welche unterschiedlichen Modi es gibt?
              Schalte die Modi mal am Terminal durch und schaue was im MQTT ankommt.
          • FRECH
            • 07.08.2017
            • 274
            Ich starte meinen Loxberry täglich neu.
            Beim Neustarten startet bei mir die Bridge nicht automatisch. (Ich denke, dass ist so gedacht.)
            Kann man den Neustart durch einen Befehl von der Loxone anstossen?
            Zuletzt geändert von FRECH; 27.05.2023, 23:46.
              Das wäre ein Fehler. Das muss ich mir anschauen.
            • FRECH
              FRECH kommentierte
              Das wäre super von dir wenn du dir das anschauen könntest.
              Wüsste nicht wie ich das bei mir ändern kann... DANKE
            • 5374
            Felda1974 Please try the latest Master: https://github.com/mschlenstedt/LoxB...heads/main.zip
            You should be able to select Fairland in the Type Dropdown. Can you please give me the exact Type/serie of your Fairland for which the JSON is valid for? Thanks.
            • Felda1974
              • 14.06.2022
              • 4
              @Prof.Mobilux​ Thank you!!! :-) I succesully instaled.
              I used "JSON definition" from your recommended source: https://github.com/make-all/tuya-loc..._heatpump.yaml
              In MQTT gateway I can see a combination of names and raw. - see a printscreen.
              It looks correct.
Ansichten: 492
Größe: 1,14 MB
              As I wrote you before, I use Fairland Rapid Inverter RIC33 - IPHCR33.
              But it will be the same for a whole serie.
              Marek
                • 5374
                Ok, Perfect. The status_raw shows the ID while status should show the mapped name.
                  • 5374
                  Probiere bitte mal den neuen Master: https://github.com/mschlenstedt/LoxB...heads/main.zip
                  Damit sollte nach Reboot die Bridge automatisch gestartet werden.
                  • FRECH
                    FRECH kommentierte
                    Bin heute wieder zurück aus dem Urlaub und werde es morgen gleich testen... =)
                    Danke!
                  • FRECH
                    FRECH kommentierte
                    Habs mir doch gleich angesehen und es funktioniert bei mir =))))
                • FRECH
                  • 07.08.2017
                  • 274
                  Was mir noch aufgefallen ist...
                  In der Loxone wird angezeigt, dass die Bridge läuft, obwohl sie nicht läuft: (Grundsätzlich hat das funktioniert. Ich werde das mit der neuen Version weiter beobachten.)
Ansichten: 236
Größe: 54,1 KB
Ansichten: 236
Größe: 183,3 KB
                  Ist das vlt auch bei wem anderen so?
                  Danke und LG
                    • 5374
                    Musst Du mal beobachten - bei mir funktioniert es:
Ansichten: 235
Größe: 77,5 KB
                    ​​Klicke auf die Grafik für eine vergrößerte Ansicht
Ansichten: 233
Größe: 110,3 KB
                  • Paz
                    • 24.02.2022
                    • 241
                    #30
                    Servus Prof.Mobilux!
                    Ich hätte nun auch noch eine Frage (oder zwei):#
                    Kann ich die Bridge auch via Loxone neu starten? Ich schalte die Poolex mittels Energiemanager per Schütz ein/aus (da es da dein Plugin noch nicht gab), da nimmt sich die Bridge immer das Leben und deswegen würde ich sie mit dem EM mitstarten. Oder sollte sie ohnehin ein Keep-alive haben (wäre natürlich noch schöner)?
                    Und werden die Fehlermeldungen nur im Fehlerfall mitgesendet? Bei dir sieht man Error (9) auf 0. Bei mir gibt es den nicht.
                    Vielen Dank nochmal,
                    Patrick
