MusicServer4Home - v1.3.0.0 mit MusicServerGateway
  • kob004
    • 18.02.2021
    • 11
    No effect ... still no room fav in LoxConfig
    Any idea? Thanks
    the file /var/lib/squeezeboxserver/prefs/favorites.opml below:
    <?xml version="1.0" encoding="UTF-8"?>
    <opml version="1.0">
    <head title="Favoriten">
    <expansionState></expansionState>
    </head>
    <body>
    <outline URL="http://www.mysqueezebox.com/public/opml/477e7ceab3b7a7761719f3f57e4edc21563370b7/favorites.opml" icon="html/images/favorites.png" text="Na mysqueezebox.com" />
    <outline URL="http://opml.radiotime.com/Tune.ashx?id=s24937&amp;formats=aac,ogg,mp3&amp;pa rtnerId=16&amp;serial=98c0bb280d3e765954c853e6a334 6302" icon="/imageproxy/http%3A%2F%2Fcdn-radiotime-logos.tunein.com%2Fs24937q.png/image.png" text="Rock Max" type="audio" />
    <outline URL="http://opml.radiotime.com/Tune.ashx?id=s25088&amp;formats=aac,ogg,mp3&amp;pa rtnerId=16&amp;serial=98c0bb280d3e765954c853e6a334 6302&amp;filter=s:popular" icon="/imageproxy/http%3A%2F%2Fcdn-radiotime-logos.tunein.com%2Fs25088q.png/image.png" text="Radio Beat 95.3 (Classic Rock)" type="audio" />
    <outline URL="http://opml.radiotime.com/Tune.ashx?id=s15666&amp;formats=aac,ogg,mp3&amp;pa rtnerId=16&amp;serial=ea6d7abb8f27cdf053901644a33a 3fee" icon="/imageproxy/http://cdn-radiotime-logos.tunein.com/s15666q.png/image.png" text="Evropa 2" type="audio" />
    <outline URL="http://opml.radiotime.com/Tune.ashx?id=s25127&amp;formats=aac,ogg,mp3&amp;pa rtnerId=16&amp;serial=98c0bb280d3e765954c853e6a334 6302&amp;filter=s:popular" icon="/imageproxy/http%3A%2F%2Fcdn-radiotime-logos.tunein.com%2Fs25127q.png/image.png" text="Radio Impuls 96.6 (Pop)" type="audio" />
    </body>
    </opml>
      • 7357
      Davejje
      The Aureon is a good sound card that use USB1.1 als Protocol. (12Mbit)
      If your USB Chip is not using MTT Protocol the hole USB3 Chip use that USB1.1
      When you use then 2 second sound card, they share the 12Mbit and than it isn't enough for bout.
      Simple Solution there....
      Use a MTT USB-Hub link the LogiLink UA0148, then every Port with a sound card use USB 1.1 but the rest stays at USB2.0 (480Mbit).
      • Leigh
        • 710
        hismastersvoice
        Are there any plans to integrate Sonos also?
        Ciao, Leigh
          Sonos can be used with UPnP (Models without Airplay) or new Models with AirPlay-Bridge Plugin as external Zone.
          Without Airplay the Zones are not playing synchron like with Airplay. But that is an issue of the Protocol and I can't do anything against.
        • Leigh
          Leigh kommentierte
          Okay.
          Looks like i just have to figure it out, if this is an Option for me.
          THX
      • Davejje
        • 24.11.2017
        • 173
        hismastersvoice i have order direct a logilink UA0148 Normlay i will be here tomorrow! i hope all the problems are solved.
        Than i can finisch the full migration from loxone music server original to the MS4H
          I believe that this solve you problem, any all the other case that was the solution.
          Please give feedback, even if it works
        • 7357
        Any idea? Thanks
        I have installed a new server to check, and even if there are no Roomfavs in a Zone it always shows Roomfav 1-8.
        So there is no sync between the Config and the MusicServer. So the MSG can't do anything here.
        Backup you Loxone-Config-File
        You can go into the Loxone Config File with an Texteditor and search for BuzzMode=
        Here you can do 0-9 that it looks like BuzzMode="3"
        1=play/pause
        2=buzzer
        3-9=RoomFavs 1-8
        Save the file and open it in Config again.
        Look in to the changes Zone if it now shows the Roomfav-Option.
        • kob004
          • 18.02.2021
          • 11
          1=play/pause
          2=buzzer
          3-9=RoomFavs 1-8
          I have done, this but no effect, only empty line, no Rommfav-option
          I have installed new MS4H and no changes, still no Roomfav-option
          Can't the problem be only in external zones??
          • kob004
            kob004 kommentierte
            I have done all this. No result ....
            OK... If found the issue.
            In Config 11 works fine, in Config 12 not.
            This a (another) Loxone Bug, will open a Ticket @ Loxone.
            I can't believe how many bug Loxone is producing.
            During the development of MSG, there where in every Version new bugs, if they solve one we get 1,2,3 new ones
          • kob004
            kob004 kommentierte
            Thanks for your investigation. I will be wait ....
        • Davejje
          • 24.11.2017
          • 173
          hismastersvoice for now it looks link that the logilink AU0148 solve the problems!
          I can leave the VM settings on USB 2.0 with 2 or more soudncards connected to the usb hub, and the sound is cristal clear!
          For everyone i connect the usb hub to my Qnap NAS do not forget the external power source for the hub otherway it dont work!
          In the hub i connect all the usb sounds-cards. Assigne the soundcard to the right vmware inside virtual station and reboot the system.
          • Leigh
            • 710
            ​So, nun hab ich das ganze mal getestet und muss sagen,
            hismastersvoice
            DANKE DAFÜR.
            Und hier meine MS4Home Lösung.
            Ein Raspi4 - 4GB im Geekworm X825-C6 Gehäuse, dazu das HDD/SSD Extension-Board X825, das Power Management Board X735 und ein entsprechendes Netzteil mit 4A.
            Die HDD ist eine alte 2,5" HDD mit 1TB Kapazität für viel Musik.
            Klicke auf die Grafik für eine vergrößerte Ansicht  Name: IMG_7842.jpg Ansichten: 0 Größe: 761,4 KB ID: 296453Klicke auf die Grafik für eine vergrößerte Ansicht  Name: IMG_7843.jpg Ansichten: 0 Größe: 725,1 KB ID: 296454Klicke auf die Grafik für eine vergrößerte Ansicht  Name: IMG_7845.jpg Ansichten: 0 Größe: 754,1 KB ID: 296456Klicke auf die Grafik für eine vergrößerte Ansicht  Name: IMG_7847.jpg Ansichten: 0 Größe: 752,6 KB ID: 296455Klicke auf die Grafik für eine vergrößerte Ansicht  Name: IMG_7849.jpg Ansichten: 0 Größe: 578,1 KB ID: 296452
            Ciao, Leigh
            • Iluminatus23
              • 07.08.2016
              • 233
              1=play/pause
              2=buzzer
              3-9=RoomFavs 1-8
              Ich weiß nicht, ob es in diesselbe Richtung geht, aber bei mir funktioniert seit dem letzten MS4H Update die Funktion "Nächster Zonenfavorit" nicht mehr. Der Eingang "S+" wird wie immer geschaltet, aber es springt eben nicht auf den nächsten Favorit....an was könnte das liegen?
                • 7357
                Das eine hat mit dem anderen nichts zu tun.
                Habe gerade einen Test gemacht bei meinem System, geht mit S+ zum nächsten Fav.
                Da keine weiteren Daten zur Verfügung gestellt wurden kann ich dir nicht helfen.
                • Iluminatus23
                  • 07.08.2016
                  • 233
                  Danke erstmal für die schnelle Antwort. Vielleicht hilft das weiter: Seit dem Update sehe ich auch keine "iconbilder" der Favoriten in der Loxoneapp mehr. Auf der Weboberfläche des LMS hingegen schon!
                  Entschuldige die fehlenden Angaben. Du hilfst immer gut und die Spielregeln machen auch SInn:
                  Also ich nutze jeweils die neuesten Versionen. Miniserver und App sind auf dem letzten Stand und auch der MS4H. Mit der 1.2er des MS4H ging es noch und mit der Config auf V11.x.
                  Derzeit erscheinen auf meinem Handy mit der neuesten Appversion keinerlei Icons. Auch die Radioauswahl ist seit dem neuesten MS4H Update weg. Mit 1.3 waren diese Menüs noch da. Interessanterweise ist bei gleichem Setup auf dem Handy meiner Frau mit der Loxoneapp in V11 "defekte" Icons zu sehen. Screenshots liefer ich noch.
                  Eine Frage: Ist ein Downgrade des MS4H möglich?
                  Zuletzt geändert von Iluminatus23; 17.03.2021, 10:40.
                • Iluminatus23
                  • 07.08.2016
                  • 233
                  Also seit dem heutigen Update funktioniert wieder alles bestens!!! Vielen Dank hismastersvoice
                  Die Icons werden wieder angezeigt und auch S+ geht einwandfrei.
                  Das einzige was seit Version 1.2 (?) auftritt: Die Weboberfläche läd manchmal extrem langsam. So dauert es bis zu 30s eine Unterseite aufzubauen...
