Problem accessing ports
  • tnagpal.
    • 11.05.2019
    • 90
    On my second server, I am seeing "Can not reach server!" under Music Zones.
    Config Checker - green
    Check ... MusicServer Config -> All required parameters are available.
    Check ... User Config -> All required parameters are available.
    Check ... Version Config -> All required parameters are available.
    Check ... Statistic Config -> All required parameters are available.
    Check ... LMS Config -> All required parameters are available.
    Check ... MiniServer Config -> All required parameters are available.
    Check ... PowerManger Config -> All required parameters are available.
    Check ... Squeeze2Lox Config -> All required parameters are available.
    Check ... Language Config -> All required parameters are available.
    Check ... Folow-Me Config -> All required parameters are available.
    Check ... FritzCallMonitor Config -> All required parameters are available.
    Check ... Text2Speech Config -> All required parameters are available.
    Check ... Ring / Alarm Config -> All required parameters are available.
    Check ... TavelTime Config -> All required parameters are available.
    Check ... Weather2Speech Config -> All required parameters are available.
    Check ... Announcement Config -> All required parameters are available.
    Check ... Network Config -> All required parameters are available.
    Check ... NAS Config ->All the required parameters are available.
    Check ... Mail Config -> All required parameters are available.
    Check ... T5 Config -> All required parameters are available.
    Check ... KNX Config -> All required parameters are available.
    Check ... Zones internal Main-Config -> All required parameters are available.
    Check ... Zones external Main-Config -> All required parameters are available.
    But support data shows unavailable ports:
    Port 22 reachable
    Port 80 reachable
    Port 443 reachable
    Port 7091 not reachable
    Port 7092 not reachable
    Port 9000 not reachable
    Port 9090 not reachable
  • tnagpal.
    • 11.05.2019
    • 90
    Went to the LMS setting page and saved and it worked. Some minor thing.
      • 7599
      I can't check if changeable Settings are wrong, I can only check if the keys/values exist.
      e.g. LMS
      if you set different Ports than 9000/9090, I can not say the Settings are wrong.
      In the Support-Data I take the saved Variables for IP / Web- / CLI-Port and check if they are reachable.
      Like in your case 9000/9090, and they are not, so why I can't say.
      I will add the vales of LMS to support-data, so I can see next time if something is wrong in these data.
      PS: Still the MOTU 24AO is not supported by Alsa "More than 8 channels - loxforum.com", and also internal sound cards, so I don`t support if you play around with settings to get it run.
      • tnagpal.
        • 11.05.2019
        • 90
        No worries on th 24ao - I recognize it is an unsupported device. Just experimenting with it right now.
        I am having the port issue intermittently with both servers (the regular one and the one running the 24ao), plus the WebGUI and the networking settings are quite strange.
Name: Screenshot 2021-03-07 175558.png
Ansichten: 348
Größe: 43,3 KB
        Config-checker:
        Checking...MusicServer Config --> All Required Parameters are found.
        Checking...User Config --> All Required Parameters are found.
        Checking...Version Config --> All Required Parameters are found.
        Checking...Statistic Config --> All Required Parameters are found.
        Checking...LMS Config --> Missing Variables: LMS_8, LMS_LATEST
        Checking...MiniServer Config --> All Required Parameters are found.
        Checking...PowerManger Config --> All Required Parameters are found.
        Checking...Squeeze2Lox Config --> All Required Parameters are found.
        Checking...Language Config --> All Required Parameters are found.
        Checking...Folow-Me Config --> All Required Parameters are found.
        Checking...FritzCallMonitor Config --> All Required Parameters are found.
        Checking...Text2Speech Config --> All Required Parameters are found.
        Checking...Ring/Alarm Config --> All Required Parameters are found.
        Checking...TavelTime Config --> All Required Parameters are found.
        Checking...Weather2Speech Config --> All Required Parameters are found.
        Checking...Announcement Config --> All Required Parameters are found.
        Checking...Network Config --> All Required Parameters are found.
        Checking...NAS Config --> All Required Parameters are found.
        Checking...Mail Config --> All Required Parameters are found.
        Checking...T5 Config --> All Required Parameters are found.
        Checking...KNX Config --> All Required Parameters are found.
        Checking...Zones internal Main-Config --> All Required Parameters are found.
        Checking...Zones external Main-Config --> All Required Parameters are found.
        Checking...Zone 1 intern Config --> All Required Parameters are found.
        Checking...Zone 2 intern Config --> All Required Parameters are found.
        Checking...Zone 3 intern Config --> All Required Parameters are found.
        Checking...Zone 4 intern Config --> All Required Parameters are found.
        Checking...Zone 5 intern Config --> All Required Parameters are found.
        Checking...Zone 6 intern Config --> All Required Parameters are found.
        Checking...Zone 7 intern Config --> All Required Parameters are found.
        Checking...Zone 8 intern Config --> All Required Parameters are found.
        Checking...Zone 9 intern Config --> All Required Parameters are found.
        • hme0354
          • 06.07.2019
          • 1018
          very interessting IP-Adresse. Maybe thats your problem?
            • 7599
            100% that is also your issue with the not reachable LMS.
            Do you have more than one NIC at your Board?
            If yes, deactivate one.
            • tnagpal.
              • 11.05.2019
              • 90
              Yeah, something weird. Don't have 2 NICs and this server was working fine until I rebooted it.
              Now the webui crawls. Players are not showing on LMS like it isn't connecting to LMS internally either.
              No dual-NICs.
              This is happening on both servers but ethtool and the rest are normal.
