Doorbell problem
  • kob004
    • 18.02.2021
    • 12
    Doorbell problem
    doorbell doesn't work on my site. Music and TTS works fine.
    MS4H v. 1.5.5.9
    Loxone Config v13.3.2.8
    Log below.
    Please help. Thanks a lot.
    Milos
    Log.
    2023-02-16T11:20:18.842Z MSG:WSCK RECV:audio/grouped/bell/1~50,2~50,5~50,6~50,8~50,9~25
    2023-02-16T11:20:18.843Z MSG [WARN] [HTWS] Unknown command: audio/grouped/bell/1~50,2~50,5~50,6~50,8~50,9~25
    2023-02-16T11:20:18.844Z MSG:WSCK RESP: {"bell_result":null,"command":"audio/grouped/bell/1~50,2~50,5~50,6~50,8~50,9~25"}
    2023-02-16T11:20:19.874Z MSG:WSCK RECV:audio/grouped/bell/off/1,2,5,6,8,9
    2023-02-16T11:20:19.874Z MSG [WARN] [HTWS] Unknown command: audio/grouped/bell/off/1,2,5,6,8,9
    2023-02-16T11:20:19.875Z MSG:WSCK RESP: {"off_result":null,"command":"audio/grouped/bell/off/1,2,5,6,8,9"}​
    • 7664
    Only for the MusicServer-Block implemented not for Group-Events.
    • kob004
      • 18.02.2021
      • 12
      OK ... but .... this event is generated and sent by Loxone Doorbell-block, no by "me", it was working one or two Loxone config version ago. So, next unexpected change on Loxone side?
Name: Bez názvu2.jpg
Ansichten: 492
Größe: 513,3 KB
ID: 379837 Klicke auf die Grafik für eine vergrößerte Ansicht
Name: Bez názvu.jpg
Ansichten: 438
Größe: 267,7 KB
        • 7664
        If it has worked in the past, so i belive that Loxone has changed from sending single events to send one grouped event.
        So far, we only operate with single not with grouped events.
        So we can have a look to bring it into the MSG.
        Can you please do the follow...
        Please test also other grouped events like Alarm, Alarm-Clock and post the commands also here.
        Than we have a look to bring all of them into the MSG.
          • 7664
          ...I have found the grouped eventtyps
          alarm, firealarm, bell
          So we can have a look.
          • kob004
            • 18.02.2021
            • 12
            Hey. Hey,
            another change in the order being sent. Once again, this renders the doorbell unusable
            It looks like MS is sending the volume value in addition to the zone ID.
            Please take a look at this.
            Thank you​
Ansichten: 169
Größe: 168,8 KB
ID: 418097Klicke auf die Grafik für eine vergrößerte Ansicht
Ansichten: 116
Größe: 262,7 KB
              It has always been like this, even in earlier versions of the Config.
              We already have intergatet the grouped events into the v2 of the MS4H
          • kob004
            • 18.02.2021
            • 12
            .. but the problem is not in the group events, but in the argument that MS4h does not know, like 2~20. Do I understand right that the fix will be in v2? Thank you
              Group event for me are for me only a array of single events.
              Yes we fix that with v2
