RGBW 24V Dimmer Tree - Commoned Channels - How To
    Question about RGBW 24V Dimmer Tree. On this page (https://www.loxone.com/enen/kb/led-strips-new-build/) the following is stated:
    "The RGBW Dimmer tree has a total capacity of 200W split into 50W per channel. If required these can be commoned in order to gain for example 2 groups of 100 watts or 1 of 200W."
    This is exactly what I would like to achieve. I have 2, 24V, led strips, each of about 60-80W, and would like to connect them with 1 RGBW 24V Dimmer Tree."
    I assume that the cabling looks like this (Is this correct?):
Ansichten: 4181
Größe: 46,5 KB
    But what does the configuration look like in Loxone Config?
    • What is the Actuator Type that I should choose for the RGBW 24V Dimmer Tree?
Ansichten: 2321
Größe: 22,2 KB
    • How does the configuration take place in combination with the Lightning Controller?
      Is what has been configured below correct?
Name: Lightning Configuration 1.png
Ansichten: 3890
Größe: 13,7 KB
ID: 193134Klicke auf die Grafik für eine vergrößerte Ansicht
Name: Lightning Configuration 2.png
Ansichten: 2529
Größe: 39,2 KB
    (I tried searching within the documentation and on this forum, but this not find the necessary information to make sure I'm doing it right. If I missed something, thanks for pointing me to the right information. )
    Thanks for the help!
    Hi Ollo,
    there is the quoted answer directly from Loxone (in German): https://www.loxforum.com/forum/verka...3148#post93148
    From that perspective, your wiring scheme and settings are correct, and you need to always combine the outputs.
      Hi Christian,
      Thanks for pointing this out for me!! I did not find the answer yet (probably because it was is German).
      Although the Google Translate translation is a bit shabby, my proposed configuration seems to be correct. Give me some time to test this in real life
        FYI:
        Tested, and these are the results.
        • Cable Schema was correct.
        • "What is the Actuator Type that I should choose for the RGBW 24V Dimmer Tree?"
          => Need to be Standard Individual Channels instead of Smart Individual Channel in case of regular led strips
          Click image for larger version  Name:	RGBW 24V Dimmer - Actuator Type.png Views:	0 Size:	16.8 KB ID:	193241
        • "How does the configuration take place in combination with the Lightning Controller?
          Is what has been configured below correct?"
          => Instead of the "Smart Actuator" Type, "Dimmer 0-100%" should be used as type
          Click image for larger version  Name:	Lightning Controller.png Views:	0 Size:	11.6 KB ID:	193242Click image for larger version  Name:	Lightning Controller - Settings.png Views:	0 Size:	46.8 KB ID:	193243
        Hope this helps anyone else wondering what the configuration should look like
        Zuletzt geändert von Gast; 08.03.2019, 09:30.
          OK guys, thanks for this. Now the complication: what if I want to control those 2 LED strips as 1 group of lights? so my problem is the same, due to power load I need to bridge 2 RGBW dimmer outputs into one to support 5 meter long WW LED strip 14,4W/m2. I have in total 4 of them and I want to control all of them as one single light. how do I do that?
