Correct light mood is not triggered with motion sensor.
  • GertSt
    • 15.09.2021
    • 15
    Hi all,
    I want my motion sensors to activate a different mood depending on an operating mode. Seems easy to do in a light controller block, using the "Automatic" tab, but for some reason it just don't work.
    When I save-in my project to the miniserver, it kinda works, but it seems that, once the operating mode changes, my lights still trigger the mood for the old state of the operating mode.
    So I think the operating mode does not dispatch it changed state.
    The operating mode is set by using a Schedule block, and is attached to the AQ output. It is set as digital output. In simulation mode, all works fine.
    Should I use a trigger? How?
    By the way, I did not want to use the already existing Night mode, because I wanted a new, independent mode, that is working with a Schedule block only.
    Any tips on what might go wrong?
    Thanks!
    Gert
  • Xenobiologist
    • 15.01.2016
    • 1127
    Can you please share your config or at least some screenshots of it. thx
    • GertSt
      GertSt kommentierte
      In fact I did add some screenshots, but for some reason they are gone ....
      And once I log in, I can see them again! What's going on ...
      I will try to update the post!
  • GertSt
    • 15.09.2021
    • 15
    So strange that those image disapear somtimes ... Here's another try:
    The moods selected in the automation tab:
Ansichten: 367
Größe: 10,7 KB
    The "Asleep" operating mode is feeded by a Schedule block:
Name: schedule awake.png
Ansichten: 335
Größe: 6,2 KB
    • GertSt
      • 15.09.2021
      • 15
      I've found the issue: My Lighting Controller had a non zero value for "Alternative mood for motion" (MS), so whenever there was motion, it triggered this mood number, whatever was set in the Automatic tab.
