Miniserver logon issues
  • Dan0013
    • 20.03.2021
    • 5
    Hello everyone, severely frustrated user here .
    Been using Lox for a year or two without major issues, yesterday I wanted to add some lights and sensor for a while everything worked fine in Lox config, then without observable action from my side is suddenly could not log in anymore. Read posts and Lox info, tried a lot but no change.
    So today i swapped the SD card with a spare I had , could log in, loaded my project worked on some configs. Updates sw which in turn updated some devices.
    I let the update run and walked the dogs, when I came back the pc had gone to sleep and upon waking there was a pop-up for login attempts. Closed everything down, restarted and tried to logon but will not allow me, not even with the pw used this morning.
    Does anyone have a clue what is causing this?
    Miniserver is visible in the router and has an IP
  • Xenobiologist
    • 15.01.2016
    • 1125
    Is your miniserver reachable from the internet? Could be someone else changing your password?
    Try to add another Admin-User in your config and delete the old admin account or change the password to something new.
    • Dan0013
      • 20.03.2021
      • 5
      Thx, i will need to pick up a card reader first so i can reformat and change the pw on the spare SD card, only then can i log in and create users i think.
      • Dan0013
        • 20.03.2021
        • 5
        So, i tried to format the spare SD i pulled from the Miniserver yesterday but hardtop give up due to a failure to format. Then decidedly pull the SD that was in the server since yesterday, changed the pw in Lox config and have been working through the faultlist (AIR device offline) . For te time being access seems to work again, using local connection only, will activate port forwarding when everything is up and running.
        One minor question but would make me feel better if someone could confirm, i have 230V led lights i want to actuate through LOX. If i read the info correctly then i can just just the Q1 output on the miniserver as amps are really low and rush-in current is not an issue.
        L1 230v into Q1 which switches the output to activate the light on input from sensor or touch?
