Shelly Duo
  • belisarius
    • 05.02.2024
    • 10
    Shelly Duo
    Hello, i have a question regarding shelly duo output virtual command. The on off command works fine but i cant seem to have the brightness and output commands to work, i think its a problem with the command writing. Does anyone have a working command for brightness and temperature control of the shelly duo in loxone?
    Thank you.
    What protocol?
    With MQTT, you’ll have to publish a json with the values:
    • belisarius
      belisarius kommentierte
      I am using MQTT however I don't know how to transfer the JSON to the output command line in the "command for on". Do you have any sample for them?
    Simply paste the example json AFTER the topic in the VO Command as a first test.
    You can use the Quick Publisher in LoxBerry for testing.
    I’ve no example, but possibly there is one in the Shelly article in LoxWiki.eu
    Zuletzt geändert von Christian Fenzl; 05.04.2024, 09:52.
    • belisarius
      Thats what i have tried but it does not seem to work:
      The output command for on is:
      shellies/ShellyBulbDuo-<deviceid>/light/0/set {\r\n "brightness": 100, /* brightness, 0..100 */\r\n "white": 0, /* white level, 0..100 */\r\n "temp": 2700, /* color temperature in K, 2700..6500 */\r\n "turn": "on", /* "on", "off" or "toggle" */\r\n "transition": 500 /* One-shot transition, `0..5000` [ms] */\r\n}
      There must be something wrong with the written command and i couldnt find any other resources to help.
    You have to remove the comments from the example!
    • belisarius
      tried it, still doesnt work: shellies/ShellyBulbDuo-<deviceid>/light/0/set {\r\n "brightness": 100, "white": 0,"temp": 2700, "turn": "on","transition": 500 , `0..5000` [ms] \r\n}.
      The VO command is not compatible with the json format, the json must be turned into http command i think
      Unfortunately there is no available forum or tutorial for such issue.
    • 4483
    Shelly per MQTT Plugin - LoxWiki - LoxWiki (atlassian.net)
    Klicke auf die Grafik für eine vergrößerte Ansicht  Name: image.png Ansichten: 0 Größe: 242,6 KB ID: 428769
    Klicke auf die Grafik für eine vergrößerte Ansicht  Name: image.png Ansichten: 0 Größe: 44,8 KB ID: 428770
    • bevis0405
      • 28.03.2025
      • 5
      If you want to turn on the light with specific brightness and temperature in one command:
      bash
      http://<IP-OF-SHELLY>/light/0?turn=on&brightness=75&temp=4000 Sprunki
        This is not MQTT as requested.
    • Kuke698
      • 30.05.2025
      • 2
      For Shelly Duo brightness and temperature control in Loxone:
      Brightness (0-100%):
      http://<IP>/light/0?brightness=<VALUE>&turn=on&auth=<USER:PASS>
      Temperature (2700-6500K):
      http://<IP>/light/0?temp=<KELVIN>&turn=on&auth=<USER:PASS>
      Replace:
      • <IP> = Shelly's IP
      • <VALUE> = 0-100
      • <KELVIN> = 2700-6500
      • <USER:PASS> = usernameassword (e.g., admin:12345)
      Example:
      hope to help you
      Jumpshot Guesser
      Timeless Jewel Calculator
      Grow A Garden Calculator
      Zuletzt geändert von Kuke698; 26.06.2025, 05:41.
      • pugoing
        • 29.06.2025
        • 5
        Have you solved this problem?
        claude artifacts
        • pugoing
          • 29.06.2025
          • 5
          Did you find this execution command statement?
          Image Size Reducer
          • aaronsun
            • 07.08.2025
            • 1
            Explore the best Cartoon Network Games online
            • Kuke698
              • 30.05.2025
              • 2
              Have you solved this problem finally?
              Type Soul Tier List
              Type Soule Emotes List 2025
              • pugoing
                • 29.06.2025
                • 5
                For Shelly Duo in Loxone, the ON/OFF commands work with virtual outputs, but brightness and temperature also need the correct HTTP calls. You can do this via the Shelly light/0 endpoint, for example:
                • Switch: http://<IP>/light/0?turn=on or http://<IP>/light/0?turn=off
                • Brightness: http://<IP>/light/0?brightness=50 (range 0–100)
                • Temperature: http://<IP>/light/0?temp=2700 (in Kelvin, e.g. 2700–6500 depending on Shelly Duo’s range)
                In Loxone, simply configure these URLs as virtual output commands, and you’ll have full control of switching, dimming, and color temperature.
                BloodMoney! LoveMoney
                Zuletzt geändert von pugoing; 04.10.2025, 14:12.
