SD Card Formatting not working
  • xtlc
    • 21.04.2025
    • 3
    Hi everyone
    Whenever I try to format an SD Card with a new loxone firmware I run into
    Formatting Error 23:
    Klicke auf die Grafik für eine vergrößerte Ansicht  Name: image.png Ansichten: 0 Größe: 28,0 KB ID: 460049
    next try results in (time passed is different):
Ansichten: 129
Größe: 30,2 KB
    What I tried so far:
    • Bought a brand new SandIsk 32GB Ultra SD Card
    • Tried using an old Sandisk 16GB Ultra SD Card
    • Using a different PC (Both notebooks with win11, one a surface tab, the other one an Acer something)
    • Using a different version of LoxonConfig (14.07 and 15.3 tried)
    • Using a different SD Card reader via USB-C
    • Using a different SD Card reader via USB 2.0
    • Formatting the SD Card to FAT32 beforehand
    • Running LoxoneConfig as Administrator
    Now I kind of feel out of options - I am not able for the love of it to create a SD Card I can use. Is this so I am tricked to buy one? I am using my USB-C SD Card reader a lot because I deal with raspberries a lot and usually it flashes a SD Card in some seconds per Gigabyte. But this software takes ages (about 15 mins before I run into an error). I already tried preloading all the firmware packages.
    What I do not understand: Sometimes the flashing process until a point is very quick (maybe 20 seconds for 10%) and sometimes it slows down a lot or stops at all for more than an hour (I also tried not touching it for 2h, but broke it off after that ...). Nevertheless, whenever I reach a certain point I am thrown out by Error 23. Usually at 50 - 60%, but it appears to have some randomness. I am probably 15-20 tries deep into this and wonder if I missed something?
    Zuletzt geändert von xtlc; 21.04.2025, 16:40.
  • xtlc
    • 21.04.2025
    • 3
    Oh hier reden ja alle Deutsch Nach zig Versuchen auf mehreren notebooks parallel ist es nun auf einem endlich mal durchgelaufen und scheint zu funktionieren. Wird das Image aus dem Web gezogen?
